Old 10-25-2009, 02:13 AM   #6
YarisSedan
Drives: 08 Yaris Sedan
Possible problem with the altenator since it is in all actuality a rebuilt. Someone custom rebuilt it for more power. Easy way to check is throw your old one back in and if everything magically works then you know thats the problem. If nothing works still then you blew a fuse. Did you DISCONECT the battery before you removed and installed the altenator? If not you probally blew an important fuse thats causing all your problems.
Otherwise you may have possibly damaged the ecm
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
My Yaris Fog Light ezlove0710 DIY / Maintenance / Service 7 08-07-2009 06:15 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
