Old 10-03-2009, 07:12 PM   #181
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
What size injectors and what octane fuel?
CONGRATS MAN, enjoy it!!
no you can fix the left brake light
340cc injectors probably used on stock celicas.... fuel octane bad as below 90... Although with every full tank I fill up 1 litre octane booster.
I will fix for sure the brake light... Within these months I was too busy looking at the engine bay instead :)
Next mods DEI silicone spray on the exhaust mainfold/downpipe/turbo ceramic + DEI Titanium best wrapping out there.
In need of upgraded front suspension + semi-slics tires...
Just booked some drag races for next weekend :)
Old 10-03-2009, 07:24 PM   #182
^ nice, can't wait to see your times! going to be QUICK!!
Old 10-04-2009, 11:01 AM   #183
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
your car looks and sounds great my friend!
now, may i suggest a set of water/methanol injection kit? :)
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 10-04-2009, 02:13 PM   #184
Parmas
Parmas's Avatar
Thanks changchewsoon that will be an option for the coming future but still not in need since my intercooler hold intake temps below 25c @ 9psi.
First option will be upgrading to larger injectors maybe 632cc ones then upping the boost to finally another good tuneup session
Old 10-05-2009, 12:57 AM   #185
changchewsoon
Drives: Vios Turbo
is your current injector size insufficient? i bought FIC 445cc injectors but have not used them yet.
Old 10-05-2009, 07:50 AM   #186
Parmas
Parmas's Avatar
Correct... the injectors are about 86% duty @ 6000rpm @ 9psi. We were surprised since they are rated above 300bhp. That depends your octane mixture you are giving to the engine so if we manage to use higher grade fuel we will manage higher power with same duty cycle on the injectors.
Update : Toyo Semi-slics 195x50 888 tires were installed on all 4 wheels. Gained more handling stability and traction :)
Old 10-05-2009, 11:45 AM   #187
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Nice
Old 10-30-2009, 03:00 PM   #188
Parmas
Parmas's Avatar
Well got my hands dirty again removing downpipe and several connections to prepare them for thermal wrapping etc... and I began wondering about the braking system.
During the last runs I noticed that the braking of the car takes too much to come to a stop also when not driving that fast. I am suspecting that the heat generated by the turbo exhaust chamber is causing the "compensator" situated just few cm behind to overheat o-rings inside. I am thinking of moving the hole part to the right (front view) but that makes some more work and more expenses... I also thought of coating it with silicone spray which is designed for extreme temperatures like turbos.
What do you suggest me to do?
Old 10-30-2009, 03:07 PM   #189
make a little insulated "heat box"
Old 10-30-2009, 03:32 PM   #190
Parmas
Parmas's Avatar
What do you mean by a heat box?
You have to note that it is really tight in there!
Old 10-30-2009, 04:38 PM   #191
I'll try and take a pic from mine
Old 10-30-2009, 07:06 PM   #192
Parmas
Parmas's Avatar
That would be appreciated!
By the way what oil do you use for your motor Garm?
I use Sunoco racing oil full synthetic 10/60
Old 11-04-2009, 11:32 AM   #193
Parmas
Parmas's Avatar
Hard time to remove exhaust but finally coming to an end!
Turbo exhaust chamber, downpipe and exhaust manifold coated with DEI silicone high temp resistance paint. After paint dry wrapped turbo and downpipe with DEI titanium wrapping. Hopefully to get better engine bay temps.
Next......
- Finishing some wiring organization
- Red paint to engine cover and turbo/intercooler tubing
- Adding sandwich adapter for oil temp and pressure
Old 11-04-2009, 05:17 PM   #194
Parmas, here is the insulation box I made for the fuel system. Just a thought. You could do the same thing for your brake cylinder in the engine bay -- or anything else. This is pretty stiff aluminum with insulation on one side:
Old 11-05-2009, 12:49 PM   #195
Parmas
Parmas's Avatar
Thanks for the idea garm will check on it surely...
Old 12-02-2009, 05:54 AM   #196
Parmas
Parmas's Avatar
Some enhanced new looks.... All paint is designed to work above 500DegreesF.
Next completition of new coolant piping which will be come blue...
Also done lots of shielding at the back panel area to protect brake lines from overheating.
Old 12-02-2009, 11:20 AM   #197
Looks good man!!
Old 12-02-2009, 08:36 PM   #198
advocate
Drives: car
God this thread rocks.
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
