Old 06-03-2009, 10:19 PM   #19
JBIZZ
Drives: 2007 Liftback white
your lighter wheels will have to wear stock-sized tires to help with fuel mileage. which means your yaris will now look silly as all hell.
True. I've currently got the 7-spoke toyota alloys & have no clue what they weigh. I'd like to upgrade in the future though.
JBIZZ is offline   Reply With Quote
Old 06-03-2009, 10:24 PM   #20
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i see ur local to my shop. you interested in hub spacers with free installation?
Originally Posted by xnamerxx
you nailed it sir.
Old 06-03-2009, 10:32 PM   #21
JBIZZ
Possibly, What I really want is a turbo!
Old 06-03-2009, 10:38 PM   #22
Tamago
Tamago's Avatar
Drives: ZZW30
see my sig
you nailed it sir.
Old 06-03-2009, 10:56 PM   #23
JBIZZ
Awesome! How much would a turbo set up like yours run me? Do you have a business shop or are you a hobbyist?
Old 06-03-2009, 11:32 PM   #24
^ LOL.
He has a turbo kit he was running successfully on his xA. Now he's selling it - it would require some modifications but probably would work just fine on a Yaris.
He makes stuff, sometimes designs stuff (::cough cough:: paddle shifter), and is super knowledgable -- and regularly arrogant. An asset to the forum... most of the time.
How'd I do?
Old 06-04-2009, 01:14 AM   #25
uncleyaris
the topic, Sway = road hugging, not gas savings
Old 06-11-2009, 10:15 PM   #26
blazing blue
Drives: 08 yaris
I thouht the torsion bar eliminated the need for a sway bar...correct me if im wrong.
blazing blue is offline   Reply With Quote
Old 11-14-2009, 03:44 PM   #27
koala286
Drives: 2009 Yaris 3 Door MT
so i just want to make sure here i was thinking of ordering a sway bar for my gf's new yaris.
so no yaris comes with a rear anti-sway bar? this seems rediculous to me as its not a truck and belongs on the road only.
so if i get one any recommendation for brand? TRD, Hellwig... what do you guys think?
koala286 is offline   Reply With Quote
Old 11-14-2009, 03:54 PM   #28
Morgan
Morgan's Avatar
Drives: 07 MM LB
there are lots of threads here... check out the TRD bar, its cheap, easy to install and does a pretty good job - but I'm slightly biased. There are other brands just use the search tool
Old 11-14-2009, 06:53 PM   #29
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
FWIW, my first reaction was "huh?"... but, IF the OP is making use of the improved handling offered by a rear swaybar by simply carrying speed through turns, thereby slowing down less and having to accelerate less... there IS potential for improved MPG.
Odds are, you could do the same thing WITHOUT the rear bar, just with more body roll and less confidence. You really don't get into an understeer condition unless you're dive-bombing a turn way too fast or trying to accelerate too hard through the turn... conditions that a conscientious hypermiler would never put themselves in, anyway.
Old 11-14-2009, 07:33 PM   #30
2+2
Drives: 09 3Dr Manual
So, is your mission to convince your significant other that it's a good investment that will pay dividends with fuel savings?
I'll cosign. Sure, sure, you'll save tons of money and the fact that the car is more fun to drive is just a coincidence.
Just put the pedal down and let the devil take the hindquarters.
2+2 is offline   Reply With Quote
Old 11-14-2009, 08:04 PM   #31
Loren
What?
Loren's Avatar
Heh. The average person drives about 10k miles per year. If we assume that the Yaris is capable of 40 mpg (it is) and that adding a rear swaybar, one can carry more momentum through turns and potentially gain 2 mpg (not likely, but it's a number... let's roll with it), then you're using about 5% less fuel. If we further assume that fuel costs are $2.50/gallon... that average person will save about $30/year by installing a rear swaybar and taking corners more "briskly".
So... in theory, maybe you could recoup the money in 4 years.
Old 11-14-2009, 08:06 PM   #32
BailOut
Steals terrorist's lunch
BailOut's Avatar
Just like nearly every other "fuel saver mod", even if it manages to save some fuel it will be such a small amount that it would never cover the cost of the mod itself, nor be enough to offset the resources and energy used to create, ship and install the mod.
- Brian
Share the Road
Old 11-14-2009, 09:17 PM   #33
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I suppose the same could be said of the entire vehicle as well.
Old 11-15-2009, 07:02 AM   #34
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Don't know how much increased tire wear would cut into that, with or without a sway bar.
Old 11-15-2009, 08:05 AM   #35
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
When I started this thread I thought to myself - could it?- it seems to help me hold my speed with less throttle through turns which should in theory result in better mpg. But be assured I got the bar to actually reform our medical system. I was getting a weak stomach from all the leaning and pitching from the stock Yaris- the rear bar really cleared it up. So now President Obama- you really don't have to do that health care reform thing you've been working on- my Yaris rear sway bar solved both that pesky energy situaion AND our health care crisis!
Next - getting my rear sway bar to solve global warming and to cure cancer..........stay tuned!
Might be the best mod of the century :-)
Lewis is offline   Reply With Quote
Old 11-15-2009, 10:06 PM   #36
Loren
What?
Loren's Avatar
I'm convinced.
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 06:25 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 08:20 PM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 02:05 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
Best place to purchase a Tanabe strut bar and or TRD Rear anti sway bar? thomasward00 General Yaris / Vitz Discussion 3 07-12-2007 02:22 AM
