Old 12-12-2009, 03:57 PM   #505
ddongbap
Originally Posted by yaris07hb View Post
Before and after shots of PnutKar. Wheels are from a Mini Cooper, 42mm offset using Gorilla E/T Conical lug nuts (BMW uses studs on the Cooper). Removed the Mini logo from the center caps with a heat gun. The Toyota logo from the hubcaps would not fit within the center caps so I left them blank. Tires are Michelin Harmony, stock 185/60R15. Contemplated 195 and 205 but cost, wear, and warranty are an issue. It is my humble opinion that these wheels look very good on the car - they complement the "roundy" look nicely. Now it needs some "squat".
You mean, they use bolts. We use studs. They use bolts.
Old 12-12-2009, 06:17 PM   #506
yaris07hb
PnutKar
Drives: 2011 Liftback w/manual box
Oops - yes. They bolts, we studs.
yaris07hb is offline   Reply With Quote
Old 12-13-2009, 12:31 AM   #507
I run a set of the same Mini rims as my Winter rims. Their lug bolts are larger diameter than our studs and the hub is 2mm wider. If you aren't running hubcentric rings (I couldn't find ones to fit), you should use lug nuts that make the wheels lugcentric. I am using lugcentric bulge conical lug nuts that I found at Jegs that have the correct taper and have a part below the taper that fills the space between our studs and the wheel:
http://www.jegs.com/i/Detroit+Wheels...395-5/10002/-1
Old 12-13-2009, 07:55 AM   #508
kimona
kimona's Avatar
Drives: 2014 White VITZ
The car looks great with those mini wheels. IMO, any of the Mini wheels would compliment the car.
Old 12-15-2009, 11:27 PM   #509
yaris07hb
PnutKar
Yes, we don't want wobbly wheels do we? I used these lug nuts from Gorilla. They look similar to the Jegs nuts, but not as "bulgey". I like the Jegs better. I'll have to get some.
Old 12-16-2009, 03:20 AM   #510
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I need a set... Gorilla nakes them? I think our local shop might have Gorilla brand but not Jegs.
Top pic is Jegs and bottom is Gorilla?
Old 12-16-2009, 04:19 AM   #511
YotaYaris
YotaYaris's Avatar
Drives: 09 3dr (sold), 12 SE 5spd : )
Huh?
Its all about the MPG's !!
YotaYaris is offline   Reply With Quote
Old 12-16-2009, 09:59 AM   #512
Correct. Jegs is a supplier, the manufacturer of the Jegs ones is actually Detroit Wheels.
The flare being wider than the flats on the Jegs ones makes a better fit than the gorilla ones.
Old 12-16-2009, 11:04 PM   #513
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
CTScott - so the link you provided is the correct size/length for the Yaris?
Old 12-16-2009, 11:16 PM   #514
Yes, that link is from my order to Jegs. They come in packs of 5, so 4 packs gives you 16 + 4 spares.
Old 12-22-2009, 12:26 AM   #515
yaris07hb
PnutKar
New "bulgey" lug nuts from Jegs arrived today (thanks to CTScott for the tip). They've been installed and torqued to spec. The Gorilla's weren't going to fall off and there were no issues over the last several hundred miles, but I do feel better with these installed. A note to any others thinking of using these or similar wheels:
Unlike the Gorilla's, these lug nuts are 3/4" (19mm) hex - smaller than the stock Yaris lug nuts and therefore will not fit the factory lug wrench. I took an old lug nut from my original steelies and welded it to a sacrificial socket and tossed it in with my goody bag in the spare tire well.
I think a reminder is in order here - when changing to non-stock wheels always keep a set for your spare.
Pat
Old 12-22-2009, 12:36 AM   #516
Pat
Good reminder. I carry an X style lug wrench that will handle the factory lug nuts as well as the Jegs ones, but I don't carry 4 factory lugs for the spare.
Old 12-22-2009, 03:31 AM   #517
jethrojallas
Drives: 2009 3dr yaris
had my yaris for a while thought u guys might wanna see it
the color is red carmine metallic
the size is 18 inch wheels with 215 35 zr18 falkens
thinking of getting it lowered and i got the system for free but changed out the subs with memphis audio
just needa get an amp and hook it all up
enjoy
jethrojallas is offline   Reply With Quote
Old 12-24-2009, 06:51 PM   #518
Kal-El
Kal-El's Avatar
Originally Posted by MR. CANTON View Post
I have TRD SPORTIVO shock and spring and well the rim is 17" x 8" wide with 235/40/17 Sumitomo HTRZ tyres
& a pimped out PUP
Wow, nice setup. Tell us what rims those are!
Old 12-24-2009, 07:13 PM   #519
YarisSedan
Drives: 08 Yaris Sedan
I can finally post in this thread...
Old 12-24-2009, 09:21 PM   #520
Kal-El
Kal-El's Avatar
Nice! Are those 16's on stock suspension?
Old 12-25-2009, 01:22 AM   #521
YarisSedan
they are 15s on trds
Old 12-25-2009, 12:35 PM   #522
Kal-El
Kal-El's Avatar
Really?? Those definitely look like 16's. For some reason they just look bigger than the stock wheel size. I'm sure the drop has something to do with the illusion.
Cool.
Post pics of cylinder head (engine) covers here joelitton Cosmetic Modifications (Exterior/Interior) 157 08-02-2017 12:36 PM
My new 09 yaris! (post bath) tristan Photo-Video-Media Gallery 10 10-21-2008 02:23 PM
