Learn to Relax
The pads usually squeal, because of the wear indicators. When you hear grinding, then you've gone too far.
#2 | |
![]() Drives: 240sx want a yaris Join Date: Dec 2009
Alot of people throw away there brakes too early. I just wait untill I hear the sensors grinding on the rotors. I mean they built them damn sensors for a reason, cause those companies know we are too lazy to do any kind of pad thickness measuring or what not. |
#3 | |
One other thing to mention the last 1mm of thickness is where the binding material ie the glue that holds it to the metal plate of the brake pad. This portion of the remaining brake lining is much harder because of the glue that is saturated into it and typically you get a lot of rotor glazing if you continue to drive it. That is why most manufactures recommend replacement at 1.5mm to the sensor. Not because they want to change your brake pads early and waste your money. Because there is a reason. |
#4 | |
Learn to Relax
I don't think anyone is suggesting to do anything unsafe, but the OP just wants to know a reasonable point when the brakes should be serviced. If the service dept suggest that the brakes be serviced, then do so. If you hear the brakes squeal then go and have them checked.
| Front pad lifespan. | o89canucks | DIY / Maintenance / Service | 47 | 08-20-2012 05:39 PM |
| Looking for a nice floor mat heel pad that dosnt break the bank... | YarisSedan | Cosmetic Modifications (Exterior/Interior) | 5 | 12-14-2009 06:42 PM |
| Front/Rear Brake Wear | Zippo152 | DIY / Maintenance / Service | 17 | 06-03-2009 02:12 AM |
| Does the TRD rear sway bar promote tire wear? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 03-29-2009 10:29 AM |
| hawk performance pad non-availability explained | dsc_pat | Performance Modifications | 6 | 09-23-2007 11:58 AM |
