#20 |
![]() ![]() Drives: 2006 Yaris RS 3 door Join Date: Nov 2009
I had these two lights come on last week, and ABS didnt work during that period. Yesterday I jacked the car up, took off the rear wheels and fixed it myself - I have only a basic knowledge of fixing stuff, the most Ive done on the Yaris to date is change front rotors/pads so no expert knowledge required!
Once the wheel is off you will see a plug - the only one you will see - on the rear of the drum near the axle. A small screwdriver is needed to push the plug (gently) off the socket and hey presto....Get cleaning! I used a compressed air cleaner like one would use on a PC keyboard to clean the snow/crap out then WD40 to clean. Cleared any excess off with the air again then put the plug back. Finally a little grease on the small gap between plug and socket and wheel back on. I got in turned the key and drove off.... NO lights on.... ABS working as it should. I suggest everyone do this BEFORE going to the dealer as it will save you a fortune. It took 20 mins to do both sides and is as easy as taking off the wheel! Southern Ontario weather does cause problems to the little car, but this is a free fix... well free if you have cleaning products already in the house! If anyone wants it, PM me and ill go outside and photograph the plug area for you... But I dont know how to post it on here so ill have to email it!!! Proof its easy to do eh? |
| Tags |
| abs, abs warning light, brake warning light |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 09:50 AM |
| HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! | mizhgolightly | DIY / Maintenance / Service | 45 | 05-03-2022 03:59 PM |
| help help help big problem no brake lights | AND189 | DIY / Maintenance / Service | 9 | 11-26-2009 06:25 AM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 05:43 PM |
| What's with ABS? | jgag123 | Canada | 9 | 01-01-2009 07:04 PM |
