#19 |
![]() ![]() ![]() Drives: '09 Yaris & '10 Auris Join Date: Apr 2009
#20 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
#21 | |
fmicle's picture is a good example:
#22 |
![]() Drives: 2007 toyota yaris Join Date: Oct 2008
trailer is 12 foot
Well i lied...the trailer is actually 12 foot so is it possible now??
#23 |
Length is not a factor. What is a factor is the actual weight, and the tongue weight of the trailer in question. Find out those numbers and post them up.
#24 |
![]() ![]() ![]() Drives: 09 yaris Join Date: Mar 2009
I saw this today and thought I should post it.
http://www.youtube.com/watch?v=s4MQE...esh+div-r-5-HM
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week. |
#25 |
![]() ![]() ![]() Drives: 2007 and 2008 MM Yari LBs Join Date: Aug 2006
Two Yari on home! ![]() |
#26 |
#27 |
The Martian
No I definitely towed that thing 700 miles^-^
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker. |
#28 |
The Martian
My hitch was rated for 2000 pounds and my trailer was roughly 1200lbs fully loaded. I had no problems with power but the trailer controlled the car more than I controlled the trailer0-0
#29 |
![]() Drives: 2007 Yaris Join Date: Feb 2010
If you towed 1200lbs for 700 miles then I'm not gonna sweat towing my motorcycles to the track. Was the hitch a rental or do you still have it installed? Any idea of the make/model of the hitch? Thanks.
#30 |
The Martian
I bought the hitch. I haven't gotten around to taking it off. I believe it was a Curt Class 1 sport hitch. No place nearby had it in stock AT ALL, I had to order it from advance. I plan on using it later to haul my quad around. You can call U-Haul to see if they have it. The weight of the trailer tried to throw the car around alot. I also ended up in the middle of the first intersection I came to due to the huge increase in braking distance. This is not something that someone inexperienced with trailers should attempt.
#31 |
![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Mar 2010
I love it!
| Connecting wiring to small trailer | charles nelson | DIY / Maintenance / Service | 8 | 04-24-2012 05:39 PM |
| Towing a trailer, anyone? | fmicle | General Yaris / Vitz Discussion | 52 | 02-17-2010 06:02 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| towing is just fine... | twixt | General Yaris / Vitz Discussion | 8 | 06-01-2007 05:43 PM |
