Old 02-18-2010, 05:07 AM   #34
A1phazu1u
A1phazu1u's Avatar
Drives: Black 07 Toyota Yaris Sedan
Dye
Part of the reason some of the parts aren't taking the black dye is because they require a mixture of acetone and water in order for it to penetrate that type of plastic. the mixture should be 4 parts water and 1 part acetone. That is the strongest ratio of the mix, but you should probably start with something a little less potent.
A1phazu1u is offline   Reply With Quote
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Painting headlight housing black need diy.. YarisSedan Cosmetic Modifications (Exterior/Interior) 5 12-12-2011 10:24 PM
diy for steering wheel change aucorium Cosmetic Modifications (Exterior/Interior) 64 06-21-2010 08:46 AM
First DIY oil change but... derickveliz2 DIY / Maintenance / Service 31 02-02-2009 11:36 AM
Black Friday Bob_VT Off-topic / Other Cars / Everything else Discussions 70 11-29-2008 07:07 AM
