Old 03-20-2010, 03:38 PM   #9
R2D2
Crazy Oil Sniffer
R2D2's Avatar
If you think in regards to oil pressure the pattern you saw with the oil light would make sense if the oil was severely fuel diluted or the filter was bypassing. I would think if the sensor were the problem you would have the light coming on at "random" times, not just under conditions where the oil was good and hot.
There was a thread here a while back about someone with a similar problem and IIRC his filter was loaded to the point it was bypassing.
You state you just had the oil and filter changed, but what was the oil and filter combo you were using when you noticed the problem, and how many miles on them? Did you keep the old filter for evaluation?
Please let us know what you find out at the dealer. As others have suggested, I certainly wouldn't run the car until you find the source of the problem.
Thanks, REDDOG
-The Fitful One
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Auto Shop Local Bay Area Genuine Toyota Parts Low Low Price with Warrenty YarisSedan California 1 10-31-2008 08:32 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
Fuel low light issue Kitt DIY / Maintenance / Service 3 03-22-2007 01:44 PM
