Eh. Sweet write up. I'm def interested in this, but I am having serious difficulty sourcing the c160. Been looking for an LSD one, but can't even find the regular!
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
A few more q's.
Did it throw your speedo out? What are the chances of using the gearset minus 6th gear (just 1st to 5th) and installing it and the diff into the C150 housings (or if the centre housing is the same, just use the C150 end housing and bell housing)? |
I used the speed gears from the C160. There was only a 1 tooth difference that make the speedo read slightly slower than stock, witch in my case is better as I run slightly smaller tires than stock. But I haven't compared it to my GPS yet.
And gears 1-5 would not work in the C150. Half of First gear is part of one of the input or output shafts, I can't remember. And 5th gear tops out at about 165km/h. |
Yeah, as you can see in the pictures I took, the input and output shafts are longer to accommodate 6th gear.
It really isn't a big deal to modify the frame to fit the whole transmission in. |
#6 | |
I know, but our rules for rally cars state:
You could protest the fact that the rule says "body work" because the work needs to be done to the frame.
Or you could do the modification, grind the welds down smooth, re-paint it and make it look like it came that way from factory. I know if I was re-painting mine factory blue you never know I did anything to it. I used a rubber dead blow hammer to pound the metal in place so there's no dints, just a smooth curve and no seams. |
Nah, it's not worth the argument. The over riding rule is that you are NOT allowed to change anything unless specifically stated. In other words, it says I can change the transmission, but it doesn't say that I can change the chassis.
Can't win.
![]() Drives: Paseo Join Date: Apr 2010
So you're saying that the C160 Transmission accepted all the Original Echo motor mount brackets and locations?
Do you guys think the Final drive could swap over from a c150 to a c160?
Absolutely. That's the only way to do the swap.
The reason you can't swap them is because one caries 5 gears, and the other caries 6. Also, the C160 has an 8 bolt diff and the C150 is a 6 bolt. There would be no point in putting in the diff from the C150. It would defeat the purpose of the close ratio 6 speed. |
#15 | |
Exmple: with 205/55/16 wheels GEAR=------------------1-------2--------3--------4--------5----------6 c160 with 4.5 FD= 14.9 __ 23.1__ 31.9__ 40.6__ 51.6___ 65.3 @ 3000RPM C160 with 3.5 FD= 19.2 __29.6__ 41.0__ 52.1__ 66.3___ 83.8 @ 3000RPM c150 stock3.5 FD= 17.1 __31.9__ 46.4__ 62.7__ 71.7 _______ @ 3000RPM Last edited by Mrhiguy; 04-27-2010 at 04:54 PM. |
Yeah, but even at those speeds I still found the 5 speed was revving too low. The 6 speed as it comes make the engine work far less to accelerate the car under normal driving conditions. I'm still getting the same millage I did before the swap, maybe even a little better, if I could keep from driving it hard. My last tank yielded me 685km on 42.8L of fuel, driving on mostly back roads with hills and corners.
UPDATED WITH 3.8 FD
Exmple: with 205/55/16 wheels GEAR=------------------1-------2--------3--------4--------5----------6 c160 with 4.5 FD= 14.9 __ 23.1__ 31.9__ 40.6__ 51.6___ 65.3 @ 3000RPM C160 with 3.5 FD= 19.2 __29.6__ 41.0__ 52.1__ 66.3___ 83.8 @ 3000RPM c160 with 3.8 FD= 17.6 __27.1__ 37.6__ 47.7__ 60.8___ 76.8 @ 3000RPM c150 stock3.5 FD= 17.1 __31.9__ 46.4__ 62.7__ 71.7 _______ @ 3000RPM |
Ok well just a thought.
I guess I have to go back to the books on gear ratios. I figured if the end mph @ a certain rpm matched. Then It wouldn't matter the gear to final ratio. |
| Tags |
| 6 speed, conversion, gearbox, transmission |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 01:25 PM |
| Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast | phu@xenon-vision | Sponsors Classifieds Area | 8 | 03-06-2009 02:33 PM |
