Old 04-27-2010, 06:30 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Well, unless you can do precision machining and grinding, to remanufacture the output shaft with a different final drive gear on the end of it, there are no other options that I'm aware of.
All you can do is put on bigger 17 or 18" tires and put the speed sending unit from the Matrix XRS C60. That would get you close to the F/D you're looking for.
Old 11-02-2010, 04:20 PM   #2
carlosh
carlosh's Avatar
Drives: Yaris Sedan 2005 Motor 1NZFE
Send a message via MSN to carlosh Send a message via Yahoo to carlosh
Hi, I'm researching, the C60 transmission (toyota MR2 2003-2007, 6 speed) fit in my echo 2004.
Anyone have a feedback about that?
MR2 and echo sharing some platform or parts.
Yaris/echo 1NZFE NCP12
-> TEIN High-TECH spring, Tower bar Generic, HOTCHKIS Sway bar
-> TRD Performance air filter, Stage 1 Gripforce F1 clutch
carlosh is offline   Reply With Quote
Old 11-02-2010, 04:56 PM   #3
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
The earlier MR2's (SW20) had the gear selector arms on the other side of the box. I don't know if they changed that in the newer MR2's but it would definately be worth investigating, otherwise you will have to swap that around.
Also check to see if the holes for the transmission mount are existing in the C60, if they aren't, but the thickened casting ribs are there,then at least you can drill and tap them to suit (which I had to do on my C56 box to make it work).
rob323 is offline   Reply With Quote
Old 11-03-2010, 08:15 AM   #4
Bluevitz-rs
Yeah I'm pretty sure the shifting arms on the MR2 C60 are on the opposite side. Also, the reason I didn't use a C60 in my conversion is because the axles used are bigger than the Echo. So you'd need custom axles too. The C160 is the one to look for.
Old 11-03-2010, 04:06 PM   #5
rob323
Stock Echo axles fit in a C56 or C52 as well. But to save all the stuffing around I had to do to get the C56 to work, I would just get a C160 and mod the subframe to suit like Bluevitz did.
Old 04-13-2011, 05:12 PM   #6
Bluevitz-rs
Wow, looking back, this was TOTALLY worth it. I love the ratios of the 6 speed driving around town. This was my number one on the the wish list of mods to my car, and I've had it for over a year now.
Old 04-13-2011, 05:21 PM   #7
rob323
They should have come from the factory like this!
Old 04-13-2011, 07:29 PM   #8
Bluevitz-rs
They only thing I'd change as a factory transmission is a 4.2FD instead of the 4.5. 1st gear is nearly useless unless you're on a hill or want to take off like there's a MAC truck barreling up your A$$.
Old 04-14-2011, 02:20 AM   #9
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
Nice write up and build. Mad props.
Sponsored by: Micro Image
http://microimageonline.com
Old 04-14-2011, 03:35 AM   #10
Oh... you mean the way I normally drive.
Old 04-14-2011, 08:14 AM   #11
Bluevitz-rs
Garm, this should be on your to do list.
Old 09-16-2011, 05:16 PM   #12
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Dredging up this old thing again, I'm curious about why the Toyota B Puller set is required. Is that something that could be rented from an auto parts store? $1500 for the actual thing is a bit steep for a DIY project.
Old 09-16-2011, 05:37 PM   #13
^ good timing, I'm starting on this next week.
Old 09-16-2011, 07:21 PM   #14
CrankyOldMan
I scored that used xB transmission from scioncrew. It's arriving Monday. Looks like at least one more trip to Harborfreight is in order.
Old 09-16-2011, 08:02 PM   #15
Bluevitz-rs
I borrowed the puller set from my local dealer because I had the option to. The puller is specifically designed for disassembling the transmission. Only thing I needed to fab up was a trio of studs. I'll take a picture. You can use any pullers you'd like, just make sure they're not going to chip the teeth on the gears.
Old 09-20-2011, 11:03 PM   #16
rob323
I chipped the teeth on one of the gears on my old box trying to remove it. There is bugger all room under the gear to get the legs of the puller in there.
A bit of creative grinding on a puller might let you get under there easier without damaging the teeth.
PS, zip ties don't work
Old 10-11-2011, 07:59 PM   #17
CrankyOldMan
So you used a standard bearing puller like this or a 3-jaw puller like this?
Old 09-16-2011, 09:22 PM   #18
Bluevitz-rs
These are the studs I had to fab up. The ones I had weren't long enough so I had to weld a bolt onto each.
6 speed, conversion, gearbox, transmission
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
