Old 09-16-2011, 10:20 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Wouldn't it have been easier to just get some threaded rod and cut it to length?
Old 09-16-2011, 10:30 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
not really when your transmission is sitting on a bench in pieces. LOL
edit: it took me a whole of 5 minutes to flip the welder on and then grind and wire wheel them, so...
Old 09-21-2011, 07:11 PM   #3
johnny_vitz
Drives: 2005 Toyota Echo
^I remember that pic...
lol
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 11-04-2011, 12:20 PM   #4
CrankyOldMan
I didn't take pics of my C56 when I was tearing it down, but the 5th gear hub can be removed with a standard "bolt puller" or steering wheel puller set. The two holes in the hub should have M8x1.25 threads. Once you get the hub off, you can get a bearing separator on the upper groove of the 5th driven gear. Once that comes off, the 5th gear just slides off (it's on roller bearings). I'll try to remember to get one of the kids to take a pic of the C59 teardown.
Old 01-14-2012, 11:43 PM   #5
CrankyOldMan
So I was looking at the frame today when I changed my oil, and it looks like it's already notched the way bluevitz-RS did with his. I can't tell from the pictures, but it looks like the Vitz frame is/was square first, based on the shape of the cut off piece. Perhaps there really is hope for the NCP91 frame and a C60?
Old 01-15-2012, 07:18 AM   #6
Bluevitz-rs
Just measure the gap between the stock tranny and the frame. That'll let you know if it'll fit or not. I added about 1" of room. When I first put the 6 speed on the motor and tried to get it up into position, it JUST hit the frame by about 1/4 inch or less.
Old 01-15-2012, 11:18 AM   #7
CrankyOldMan
So it was originally notched, but you added more room? I would have taken a pic, but I didn't have a camera on me.
Old 01-15-2012, 11:36 AM   #8
Bluevitz-rs
No it was square.
Old 01-15-2012, 01:09 PM   #9
CrankyOldMan
Hmm, Now if I could just get my hands on the end cap for a C60...
Old 01-15-2012, 01:29 PM   #10
Maitre_Te_Te
Drives: Yaris 08
I think that all it's fine because an TS can have 1.8L with an other tranny!
Than the engine bay is larger than echo for this engine! I wait your reply.
Maitre_Te_Te is offline   Reply With Quote
Old 01-15-2012, 04:33 PM   #11
CrankyOldMan
The Euro T-sport 6-speed uses the EC6X series transmission with the 1.8L 2ZR-FE engine, which is a two piece casing instead of the C-series three piece design. I would guess that the gears are also narrower than the C5X/C6X series, but I'd have to have them side-by-side to verify. The gear shift cable is also unique to the Euro T-Sport, as are the mounting brackets that mate with the body (the engine/transmission side of the mounts are the same as the xD).
Avensis 6-speed gearbox (Euro):
Corolla 5-speed gearbox (US):
Old 02-18-2012, 03:00 PM   #12
10 Francis
Drives: 2010 Yaris S HB
Possibly getting a little off-topic, but does anyone have a comparison of the stock NCP91 5-speed to a JDM AE92 Corolla 5-speed (C52?), and know if it will fit?
10 Francis is offline   Reply With Quote
Old 03-07-2012, 07:30 PM   #13
Jason@SportsCar
Seems like an odd swap. The C52 has a taller 1st gear and marginally shorter final drive, the rest of the ratios are the same as the Yaris C50.
Old 06-26-2012, 08:49 AM   #14
Hussain-Vtec
Hussain-Vtec's Avatar
Drives: ECHO NCP-12/2NZ-FE
Thanks for your contribution, Great info!
I am thinking To Get a C160 LSD trans from UAE It's Available, Next Visit i will get one for my Echo i have a Question Dose the C160 transmission have a Code name on it?
The reason for my Qes is @ United Arab Emirates I No the Cars that carry the C160 trans but the thing is I have to buy the whole half cut car for the trans only, thy wont sell you the trans only.
I just buy Full Apex'e Coilovers for my Echo on the last visit.
***High-Performance Cooling System***http://honda-tech.com/showthread.php?t=3062009
***The Basics of Reading a Spark Plug***
http://honda-tech.com/showthread.php?t=3063102
ALL-TECHwire
Hussain-Vtec is offline   Reply With Quote
Old 06-26-2012, 09:01 AM   #15
Bluevitz-rs
I couldn't find any markings on the transmission that defined it other than it's physical size difference to the 5 spd. When I got it, I didn't know if it was LSD or not. And it wasn't. I just used the info on Wikipedia
Old 06-26-2012, 09:15 AM   #16
Hussain-Vtec
OH I see i No the wikipedia info.
But the thing is i need the code to find it easy, there are allot gears sitting over There and that will take my time to search for it and i have a to get some part's
for a friends and to buy a car too that is the case.
Old 06-26-2012, 11:12 AM   #17
Hussain-Vtec
OK i find this Code do you have it on your transmission, Note the number is 12 which means C160 (6-speed).
On the Wikipedia site it says (Transmission with identification code ending with 12C are LSD equipped. Code ending with 12A are non-LSD).
http://en.wikipedia.org/wiki/Toyota_C_transmission#C160
C160 ratio info.
Old 06-26-2012, 06:21 PM   #18
Bluevitz-rs
cool, I never noticed that there, I'll have to look on mine. I take it that's on top?
Actually, if that's on the bell housing, I don't have that anymore. It was sold with the rest of the 5 spd a long time ago.
6 speed, conversion, gearbox, transmission
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
