Old 04-09-2010, 09:36 PM   #19
Kenshin
Kenshin's Avatar
Drives: 2008 Blazing blue Met. HB
Stupid question but is your ground to your batter tight? Because I had fluctuations in my voltage while driving around to where even the steering was tougher at times (of course cause it's electric). So I checked my ground and it wasn't loose loose but wasn't tight either.
Just a stupid question cause yeah. . .I've been there. . .
Kenshin is offline   Reply With Quote
Old 04-10-2010, 12:34 PM   #20
MGargano
Drives: 2009 Yaris Hatchback
I checked and tightened both battery cables this morning. At first it seemed to help- 14.1v at idle and at speed, regardless of load.
This continued for a while, but after a 40 minute parkway drive (where the voltage stayed at 14.1), the voltage dipped as soon as I moved from the parkway to slower-speed city streets.
It never went lower than 13.6 though, so I guess that's an improvement. No more 13.2s, though I'm still frustrated at the inconsistency.
Old 04-10-2010, 02:09 PM   #21
if you buy the underdrive set isnt the alternator smaller to compensate and it's actually over-driven?
No, the NST alternator pulley is the same size as stock.
MGargano's inconsistent voltage is an interesting thing; I'm not technical enough to know, but how could a pulley cause that?
Old 04-10-2010, 02:11 PM   #22
MGargano
I've pretty much ruled out the pulley as the issue, since it's the same size as OEM.
I'm still curious what's causing the inconsistency, though.
Battery, cables, and pulley are out as causes, from what I can tell.
Old 04-10-2010, 03:25 PM   #23
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
yea i just tightened my belt couple minutes ago, my water pump pulley was getting a slight groove from the belt on it and it was squeaking, so i just took a breaker bar and my landlord helped me (he works on cars) so everything works fine now. I have a full NST lightweight pulley set with the 10% underdrive and never had a problem so far and I drove about 40,000 miles with them on now a little over a year, and i've been through hot weather to the deadly winter storms we just had in ny here and no problems :)
Aothachos is offline   Reply With Quote
Old 04-10-2010, 03:38 PM   #24
MGargano, have you checked that inconsistent voltage in more than one location? seems like that might help locate the root cause.
Old 04-10-2010, 03:40 PM   #25
MGargano
I haven't- I've just been going by what the Scan Gauge is displaying. Where else can I check?
Old 04-10-2010, 06:56 PM   #26
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Right at the battery with a volt meter.
Old 04-10-2010, 08:14 PM   #27
MGargano
I was doing that at first until I remembered the Scan Gauge had a voltage gauge. I can only check at the battery when I'm sitting in the driveway at idle, which is not where I'm having the problem- it fluctuates most when I'm at speed.
Old 04-10-2010, 09:42 PM   #28
MUSKOKA800
MUSKOKA800's Avatar
Alternator (expensive) or voltage regulator (less expensive/cheap). Not sure in the case of Yaris but sometimes the voltage regulator is integrated into the alternator. The battery could also be nearing its end.
If you problem resurfaces you might have a shop do a load test to pinpoint the culprit.
Old 04-10-2010, 09:48 PM   #29
MGargano
I actually bought a new battery and the issue remained, so I ruled that out as the cause and returned the new battery.
The Yaris' voltage regulator is integrated into the alternator, so I don't know how cheap it'd be to replace.
I was hoping to figure this out on my own, but it looks like my only option is a local auto electric repair place since I've checked out everything I can think of.
Old 04-10-2010, 09:50 PM   #30
Bluevitz-rs
Originally Posted by MGargano View Post
Mileage is 10,906.
With only 11K miles on it, why don't you just bring it to the dealer and ask them if there's a problem with what it's doing or it it's normal.
Old 04-10-2010, 09:54 PM   #31
MGargano
I have two amplifiers and HIDs connected to the battery along with NST pulleys, so I can't imagine that they'd cover anything alternator/electrically-related under warranty.
Old 04-10-2010, 10:16 PM   #32
Bluevitz-rs
So do I, and I've never had any questions asked about it. As long as they aren't MASSIVE 1000+ Watt amps each.
If you have the tunes pumping as you drive with the fan going, the lights on, it's totally normal for the voltage to fluctuate. That why you normally need a big capacitor hooked in parallel with the amp wiring. It reduces voltage fluctuation.
Old 04-11-2010, 10:48 AM   #33
MGargano
I just have a feeling they'll blame the amps and HIDs, whether they're what's really causing the problem or not. Maybe I can disconnect them and hide the wires, so they can't take the easy way out and use them as the cause.
I'm seeing the fluctuations with and without the load, which is what's bugging me. If it was only happening with everything turned on, I wouldn't be concerned at all.
I would definitely look into this if the fluctuation was only happening with the amps on. It's frustrating that it's happening all the time.
Old 04-11-2010, 04:11 PM   #34
Yariz
Drives: Yaris 3dr Hatchback
I picked up and installed a full set of NST pulleys a little over a year ago. To my knowledge, they were not underdrive or overdrive pulleys, just the lightened version, but apparently (thanks to CTScott's diagnosis) my alternator is under-charging the battery.
I'm not sure if this is a new issue or if it has been doing this for the past year- either way, I'm curious why/how the non-underdrive pulley set could be causing this.
When running, the ScanGauge puts my voltage at 14.1 maximum, without any kind of load (amplifiers, head unit, etc.). Even 14.1 is rare- it's usually around low- to mid-13's.
I did a search and saw some people having the same problem with the 10% underdrive pulley, but I'm curious if anyone has run into this with the standard lightened set and what a potential fix might be. Something as simple as tightening the belt? Or something more drastic?
Says on their site you may have to change the belt. Did you get this fixed?
Yariz is offline   Reply With Quote
Old 04-11-2010, 08:49 PM   #35
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
If the Scangauge is still showing over 13 volts, how can the alternator be "under-charging" the battery?
rob323 is offline   Reply With Quote
Old 04-11-2010, 11:28 PM   #36
MGargano
I ordered an alternator with 22,000 miles for $60 from the same junkyard I got the "S" gauge cluster (yard4.com), so hopefully I'll have my answer in a few days.
NST NonStopTuning Pulley Kits NonStopTuning NonStopTuning 19 11-08-2014 10:23 PM
FS: Blue Pulley Set Shijima Items for Sale by private party 12 09-18-2009 08:34 PM
NST (NonStopTuning) Ebay Feedback & Rating NonStopTuning NonStopTuning 0 07-19-2009 10:11 PM
Feeler: NST 10% Underdrive Crank Pulley - Gray Black Yaris Items for Sale by private party 10 04-29-2009 11:24 AM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 02:51 AM
