Old 03-01-2013, 06:01 PM   #1
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
Got a notice too, next oil change in about 800 mi so I'll have the dealer take a look. If they report no problems, I'm going ask for that in writing for future issues. Yet here in New Mexico other than some spot precipitation last couple of years. We are in a drought.
Killchain is offline   Reply With Quote
Old 03-01-2013, 07:15 PM   #2
jayeh
Drives: '08 Yaris LB
You can have as much of the 1 foot of snow that fell yesterday as you want. You just have to come pick it up.
Anyone in Canada get one of these?
jayeh is offline   Reply With Quote
Old 03-01-2013, 07:43 PM   #3
nookandcrannycar
Several times, both here in Texas and in Florida, I've heard natives debating cold climate natives who are complaining about the heat. Each time the discussion has ended with the FL or TX native saying 'You don't have to shovel humidity'. Each time the cold weather native has had no answer, because there isn't one .
Old 02-21-2013, 11:44 AM   #4
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i emailed toyota last week and ask even gave them the tsb #.. they emailed back and said my 2007 yaris does not fall on that tsb or recall...
Old 02-21-2013, 09:21 PM   #5
UberSilver
UberSilver's Avatar
Update, as I said before, my stock bolts were fine. But all of the creaking is gone.
So I guess the bolts had become lose over time. I also retorqued all of the bolts, so that may have done it as well.
Old 02-22-2013, 07:30 PM   #6
NEexpat
Drives: 2009, auto, 4dr LB
*Got my notice yesterday about extending the warranty on these bolts.
NEexpat is offline   Reply With Quote
Old 02-22-2013, 08:16 PM   #7
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
just got my letter the other day it reads 7 years from the vehicles date of first use or 100,000 miles whichever occurs first . mine is setting at 99,000 and need my main window switch taken care of also on a recall by toyota
pennyracer is offline   Reply With Quote
Old 04-07-2013, 10:09 AM   #8
bronsin
bronsin's Avatar
Question.
I live in NJ where we seldom have snow, and when we do, the ammount of salt they put on the road is minimal. (I grew up in upstate NY...can you say "lake effect snow"?)
Because of my physical condition Im unable to r and r these bolts. Its very inconvient to take the car to the dealer, but if necessary I will.
Has anyone had problems with these bolts who lives in an area where road salt is not an issue?
Thanks!
Old 04-07-2013, 10:35 AM   #9
bronsin
bronsin's Avatar
Ha just remembered I have an electric impact gun and a 19mm impact socket!
With the car on ramps can you get the impact gun and socket on these bolts?
Old 04-07-2013, 02:26 PM   #10
Yes
Old 04-07-2013, 01:23 PM   #11
RG01
RG01's Avatar
Drives: 07'Toyota Yaris;02 Toyota Echo
Yes, I live in SoCal and the bolts are a problem here, too! Let's start a petition and mail this to Toyota Corporate and tell them that we will go to the news corp. if we do not get a fix for their obvious crappy workmanship. I seriously was going to buy another yaris..then this. If they do not stand by their product, how can we?
RG01 is offline   Reply With Quote
Old 04-07-2013, 11:07 PM   #12
Hershey
" if we do not get a fix for their obvious crappy workmanship. I seriously was going to buy another yaris..then this. If they do not stand by their product, how can we? "
+1 .
Old 04-08-2013, 12:36 PM   #13
YarisSedan
Drives: 08 Yaris Sedan
So i havent gone through all the posts But i am going to be taking my control arms off to change the bushings soon. Is this something I would need to worry about being i live in california so rust really isnt a issue. Might as well replace it with the updated bolt while I have it off.
Old 04-08-2013, 01:41 PM   #14
Starrbri
Drives: 2007 yaris sedan standard
Some people have mentioned water running out after removing the bolts and the rust appears to be on the threads. It seems water is entering and not draining. Is there way to seal or prevent the water for entering? If the threads on the bolt are rusted, can we also assume the control arm threads are also corroded? Will it eventually need to be replaced? I just purchased a 2007 yaris and am planning on inspecting this weekend.
Starrbri is offline   Reply With Quote
Old 04-08-2013, 01:47 PM   #15
If you look at the TSB, which is either posted in this thread or in the other one on this issue, Toyota does some seam sealing when performing the TSB. Theoretically that would reduce the amount of water that can enter the sleeve. Someone on this thread mentioned drilling a small hole in the sleeve near the bolt head, and that would probably help quite a bit as well.
The control arm is not threaded. The bolt passes through it up to the body. The rusting seems to be further down the bolt than the threaded area, so presumably the body threads are fine.
Old 04-08-2013, 09:27 PM   #16
websurferdude
websurferdude's Avatar
Drives: 2007 Toyota Yaris
Can someone tell me if my VIN# JTDBT92387112623#
websurferdude
websurferdude is offline   Reply With Quote
Old 04-09-2013, 12:45 PM   #17
Starrbri
I do not believe it applies to yours as you VIN is subsequent to JTDBT923194055672
Old 04-21-2013, 08:03 PM   #18
Mtlmom
Drives: Yaris sedan 2008
Just found your forum and a great big thanks goes out to you! My bolt has broken off and I found your forum. Thank you so much for the TSB. Though my warranty is over, I do have a service call done at 53 000 km where I was complaining about the suspension making a noise and they verified and redid the brakes (in 2011)????? Wish me luck! Couldn't have done anything without you! :o)
Mtlmom is offline   Reply With Quote
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
