Old 12-13-2016, 12:16 PM   #1
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Does anyone have a copy of T-SB-0078-12 ?
Old 12-13-2016, 07:13 PM   #2
T-SB-0078-12.pdf
Old 12-13-2016, 07:35 PM   #3
NYC-SE
NYC-SE's Avatar
Thank you Scott. I had a sneaking suspicion you would have it.
Old 01-13-2017, 10:58 AM   #4
tmontague
tmontague's Avatar
Good thing you got them out when you did, mine looked about the same when I removed them 2 years ago
Old 01-13-2017, 12:50 PM   #5
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
How concerned do you think us California kids have to be about this?
On Instagram
On Wheelwell
Old 01-13-2017, 01:40 PM   #6
tmontague
tmontague's Avatar
not very likely unless you live near the coast with a lot of ocean spray.
I'd swap them at the 10 year mark if I lived in Cali. Or to save money just pull your out and coat the threads with anti seize and then coat the whole thing in marine grease. That's what i did to my new ones and after 2 years not a single thing of rust on the bolt shaft
Old 01-13-2017, 02:22 PM   #7
ern-diz
ern-diz's Avatar
Thank you, sir!
On Instagram
On Wheelwell
Old 01-27-2017, 04:02 PM   #8
RichardPan
Drives: Toyota Yaris 2007
My 07 sedan is now 10.5 years old, and I live in Ottawa, Canada, where road salts are just a fact of life. Would it be a good idea to find a mechanic to replace the bolts, before it snaps? Seems like this potential problem would be the last remaining item that would limit the service life of my Yaris. It has only 130k km on it, and engine/transmission seems to be in good shape.
RichardPan is offline   Reply With Quote
Old 09-13-2017, 10:53 PM   #9
jayeh
Drives: '08 Yaris LB
I had my old mechanic in Ottawa switch mine out. My car is a 2008 and they were replaced in 2012-14 sometime ( I can't remember!) and snapped when they were extracting them. Luckily they welded on a bolt and were able to extract them that way!
I'd get on it ASAP!
jayeh is offline   Reply With Quote
Old 12-09-2017, 03:38 PM   #10
yaris2011-07
Drives: 2008 yaris hb ce
Replaced bolts
I was able to get the bolts on my Yaris replaced. The passenger side came out without breaking. I wasn't so lucky with the driver's side.
The attached images are the driver's side bolt from a 2008 Yaris Hatchback after 10 years and 70K kms.
The new ones have been installed with lithium grease.. should last longer!
yaris2011-07 is offline   Reply With Quote
Old 01-27-2017, 07:17 PM   #11
ex-x-fire
I'd soak those bolts in lube before trying to remove them.
Old 01-27-2017, 07:48 PM   #12
tmontague
tmontague's Avatar
The issue is accessing the threads to get a penetrating lube in there.
If you have impact tools if try yourself, if they snap drive cautiously to the nearest mechanic. If you don't have impact tools then just go to a mechanic.
I can't remember but I believe the solution if they snapped was to have a bit welded onto the stud which can then be removed.
Old 04-20-2017, 06:00 PM   #13
NYC-SE
NYC-SE's Avatar
Still a problem with 3rd gen cars
This is still an issue with 3rd gen cars. Below is a pic of the passenger side LCA bolt from my 2014 SE. I changed them out a week ago because the front end was making a clunking noise and I suspected that the LCA bolts were the issue. They were. No more clunking now. You can read about my adventure here:
http://www.yarisworld.com/forums/showthread.php?t=57576
For those who suspect this may be an issue with their car: The only symptom I had was the clunking noise. The car rode, handled, steered, braked fine. Everything that you could see of the front suspension looked fine too. That's the problem, the LCA bolts are hidden. If you are in a heavy salt area and you are clunking you need to check the LCA bolts.
I was able to R&R the bolts with the car on the ground without a problem. As others here have suggested I coated the new bolts with a high quality calcium sulfonate marine grade grease before installing them. Should help for the future, but I'll be inspecting them every year going forward.
Toyota needs to update the TSB to include ALL model years and they need to extend the warranty on this to 3rd gen cars as well.
P.S. This thread needs to be made a sticky.
Old 04-20-2017, 06:28 PM   #14
tmontague
tmontague's Avatar
FYI, I had also originally planned on pulling the bolts once per year but after coating them virtually the same as you and pulling them to inspect after 1 year, I now just check them every 2 years. Even at 2 years they're virtually untouched.
It's your call but I figured I'd give my input to save you some hassle as your roads are similarly coated in brine for 4 months of the year like ours are.
Old 04-20-2017, 09:16 PM   #15
NYC-SE
NYC-SE's Avatar
I think I'll pull them in a year anyway just to satisfy my curiosity. I would expect them to be in good shape. After that probably every 2 years. I figure if they can survive for 3 years with no protection they should be fine after 2 with a good coat of grease.
Old 04-22-2017, 07:58 PM   #16
Cartel
Cartel's Avatar
Drives: 2007 Yaris Hatch is sold
toyota pig iron...I'll have to inspect mine after seeing this disaster
Cartel is offline   Reply With Quote
Old 09-10-2017, 03:38 PM   #17
bladesmith6
Drives: 2007 yaris HB
Warning
Well i finally checked mine on my 2007 and glad i did, the driver side was looking really bad. Well coated the new ones in grease and installed with no real drama.
bladesmith6 is offline   Reply With Quote
Old 12-09-2017, 05:29 PM   #18
NYC-SE
NYC-SE's Avatar
My God, I think those are the worst I've seen yet!
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
