Old 01-09-2007, 12:55 AM   #1
machine1
machine1's Avatar
Drives: 07 Yaris Liftback
Send a message via AIM to machine1
Engine Management
Are there any companies coming out with a plug and play standalone (i.e. AEM) for the Yaris anytime soon?
I know Motec and Haltech are around but I would have to do a lot of rewiring to the engine harness, which I would probably end up having to do if nobody decides to make a unit for us Yaris owners.
Piggybacks work but are limited, no anti-lag, timing control, etc. Hondas are so much easier, lol.
I want to see if this 1.6 liter can put down 250 to the ground reliably with the stock bottom end. We were able to do it with a 1.6 liter SOHC Honda motor, but it took ARP studs and a 1.2mm headgasket to do it.
Anyways, we need a standalone system.
machine1 is offline   Reply With Quote
Old 01-09-2007, 09:23 AM   #2
TrancosRt
TrancosRt's Avatar
Drives: 07 Silver HB Yaris
I don't know about that, but the Yaris' engine is 1.5, not 1.6 ;)
TrancosRt is offline   Reply With Quote
Old 01-09-2007, 07:37 PM   #3
Biggie™
Biggie™'s Avatar
Drives: '07 3 Door Yaris of Doom!
Call COBB Tuning and ask for Justin, 801-713-0035. COBB released information that they are producing an AccessPORT for Toyotas some time in 2007.
The AccessPORT is a small hand held tuner that plugs into the factory OBD2 port allowing you to completely tune the factory ECU. No need for piggy backs or standalones. Just the AccessPORT and no other mods makes like 30-40 HP on a WRX so it should be your first engine modification on a Yaris.
Biggie™ is offline   Reply With Quote
Old 01-09-2007, 07:49 PM   #4
spkrman
Drives: 1
tell em hurry up! There is a hungry market for these things
maybe I'll give em a ring tomorrow :)
Old 01-09-2007, 08:47 PM   #5
machine1
machine1's Avatar
Thanks for the info.
The Yaris was victimized by baseball sized hail. I drive a new Civic now.
Old 01-10-2007, 12:22 PM   #6
Biggie™
Biggie™'s Avatar
Originally Posted by cdydjded View Post
Bigggie: Do not expect 30-40hp on a N/A motor, the WRX gets those type of gains do tune VERY conservative factory tuning. Also any turbo motor will gain that much when not rellying on the factory computer.
Haha, I know... I actually work for COBB and want the AccessPORT for my own Yaris. I just know how things work, with a noticeable demand the priorities might change in our favor.
If every Yaris owner on this site calls in, I'm sure it will motivate production!
Old 01-10-2007, 02:18 PM   #7
spkrman
Drives: 1
and then I looked at the prices, lol owwww
although, if they even exist, it means someone will buyone, and someone will take $5 to let me play with it :)
Old 01-14-2007, 07:32 PM   #8
calmcool
Drives: Echo Hatchback
Well you must talk about the piggyback devices that sale from after market manufactures. HKS, Gredddy, and Blitz USA offer plug and play on board programmer devices for natural aspire and compressed engine.
Have fun!
calmcool is offline   Reply With Quote
Old 01-16-2007, 03:49 PM   #9
Schwebel
Drives: Soon to be Yaris
Not having a plug and play, like Hondata, is what is holding back unleashing the Yaris' potential. Like said before it is so much easier to get big bhp out of a Honda, but everyone and their brother has one, including me. And Honda's have become boats over the years. I have a k20a2 swaped 2004 EP3 and it weighs over 2850lbs and it is considered the light weight hatchback of the Honda line. Someone out there has to realize the potential a 2200lb hatchback has and build a dam plug and play ecu.
Schwebel is offline   Reply With Quote
Old 01-16-2007, 08:27 PM   #10
machine1
machine1's Avatar
Yeah, my Honda is so easy, everything's there for it. I'm hoping the Yaris will eventually become that way.
Old 01-21-2007, 03:07 PM   #11
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Unfortunately, Yaris does not gain so many hps easily...
Old 01-31-2007, 02:25 PM   #12
calmcool
Any Toyota Ecm from up to 2000 are all fully programmable. So have fun.
Old 01-31-2007, 02:27 PM   #13
calmcool
One last warning, WE DON'T HAVE GOOD FUEL HERE IN AMERICA!!!
Old 02-01-2007, 08:57 PM   #14
yarisTOONR82
feed me knowledge!!!
Drives: 2007 Toyota Yaris 3dr HB.
here's something from echodrivers USA site on the limitations of the 1nzfe engine
Turbo charging the 1nz-fe has proven to be chore. It responds to boost quite nicely with a properly sized turbo. But its downfalls are the internals and its engine management.
Lets touch on the internals. First and foremost are the rods. Although quite strong for their size, they are designed for normal aspiration only. A half point higher in compression is about all they can handle daily without failure. Once boost is added to the equation, it becomes Russian roulette as to when they will let loose. You may last eight months with 50,000 miles or blow it the first pass down the street; there are no warning signs. We know this because of the testing of our turbo kit for the last year. The testing started on the Echo then was transferred to a Scion. The testing was controlled and only once was it taken past its set 7-psi mark while in our possession. Its one time high boost pass on the dyno was done to see how much the turbo would produce at maximum efficiency. Fueling and timing were changed to handle this. Every month the pan was dropped and there were no signs of abnormal rod bearing wear. The compression was straight across the board every time. The first motor lasted 6 months with about 35,000 miles. Its life was cut short while at the paint shop. Rumors placed it at the local street races near the paint shop, which they had for 3 weeks. All the baked on rubber in the fender well was the first clue. It let loose on its way back from them. A fresh motor was installed ASAP to continue the testing. The old motor was broke down to find the rod broke right above the crank pin. The dangling rod was beaten into the walls and punctured holes on both sides of the block. The second one let loose 12,467 miles later. It had seen one race with 3 passes at 9 psi. Fueling and timing were also changed to handle this. Other than that it was daily driven. The rods let go again, the same way, only this time it punctured the water jacket and destroyed the head. These engines have the crankshaft offset 12mm to the thrust side of the cylinder bore centerline. This reduces the side force generated at maximum compression, for reduced friction and improved fuel economy. Toyota calculates the offset crankshaft configuration reduces fuel consumption by between one and three percent. Unfortunately, this throws the angle of the rod way out on its upward travel causing the rod to just give up under boost and snap. If there is any detonation or pre-ignition this breakage will occur at an accelerated rate. The movement and breakage of the cylinder walls is the same as Honda’s open deck. Although we have yet to split one, we designed a block guard just in case. This product keeps cylinders from moving around and from splitting open the top of the bore. We are currently designing a forged replacement rod as well as a rod piston combo for high boost applications. The first of the sleeved blocks is being tested now.
Now for the ecu. It cannot handle boost in its stock form. Its timing is set for the stock parameters only. It will not handle larger injectors either. Piggyback or stand-alone management is needed to fuel the turbo properly, end of story.
From what we have seen, these issues probably were found by the likes of Blitz and Greddy long before we did. That’s why the boost on their kits was so low. The stock injectors will supply enough fuel for 3 to 4 psi if the MAF reaches full voltage and gets the injectors to 85 percent duty. Unfortunately you end up with a 15:1 AFR at peak rpm this way. Good for passing emissions but bad for the motor. The RS turbo Vitz has an ecu calibrated for the larger injectors that feed 150 ps at the flywheel which in turn is 127 ps at the wheels. The blitz s/c was turning 122 hp to the wheels without an ecu for the US market. With the ecu (JDM only), the s/c put down 129 ps to the wheels. It seems like the kits are limited to 150 at the flywheel but no one says how long it will last. Our turbo kit produced 144 hp and 150 tq to the wheels. That’s 170 hp at the flywheel. We have worked with several management systems and we will inform the public of the best one for our kit. We will release our kit soon but cannot warranty it except for workmanship. This kit will push your engine over the edge in the long run but if you build it our kit will be able to provide up to 250 hp at the flywheel. That’s 217 at the wheels. With all this said, it is up to you, the consumer, to decide whether this kit is right for you.
yarisTOONR82 is offline   Reply With Quote
Old 02-02-2007, 12:24 AM   #15
machine1
machine1's Avatar
Interesting...
Old 02-02-2007, 02:11 AM   #16
spkrman
Drives: 1
link to the original post?
Old 02-22-2007, 11:26 PM   #17
FlintArrow
Drives: Flint Mica 2007 Yaris S M.T.
There are plenty of piggybacks that provide advanced features including timing control. You definitely wont find a means to remove the redline w/o a standalone or reflash.
Until I see someone crack Toyota's ECU's for the 1nz, 1zz, 2zz, etc I wont hold my breath. Its probably more of a supply/demand issue than "it cant be done". Still, with cars like the Celica GT-S and the MR2 Spyder over the past 6 years, then the Scion rave why hasnt anyone thought of it until now?
If you want engine management at this point there are plenty of great piggybacks that have timing ability: Unichip, Greddy Emanage (blue or ultimate), or the new AEM Fuel and Timing controller yet to be released.
For those seeking ultimate control AEM just released their Universal EMS, or you could go with a proven system like the Hydra or Motec.
I cant wait for a plug and play so hurry up Cobb!
FlintArrow is offline   Reply With Quote
Engine Swap Nutzoids Performance Modifications 42 10-01-2007 06:20 PM
Engine upgrades aucorium DIY / Maintenance / Service 7 01-10-2007 05:03 AM
if i am thinking about an engine swap - from 1.3 to 1.5 - please help ASHRAF Performance Modifications 15 01-03-2007 01:40 PM
Engine mods - why bother? RallyYaris Performance Modifications 143 12-24-2006 03:56 AM
Noisy Engine David81 New YARIS Purchase Forum 8 06-02-2006 12:15 PM
