Old 05-08-2010, 11:27 PM   #1
Just as a heads up when you pull the right hand trim piece off from the center console there is a round hole which looks to be that size to accommodate the push to start mechanism. I was going to use that hole for another project however this has my mind moving in a different direction. All one with a sedan would have to do is punch out the correct size hole and then would be able to mount the PTS I would wager.
Any insight or ideas on this CTScott?
I just ran into this picture of Cyberfrogg's. This hole to the left of the radio is the PTS switch mounting hole:
CTScott is offline
Old 05-09-2010, 02:48 AM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Yup...that is it which means that if the part number could be found then there must be a replacement panel for the sedan overseas that already has the hole as a factory spec...I was going to use it to run my USB for my HU through, but might need to 86 that idea and find a new spot as I kind of like the idea of the PTS...
fnkngrv is offline
Push Button Start Stoln Europe (continental) 20 05-24-2010 08:56 AM
push start vs electric start? yaris2010RS General Yaris / Vitz Discussion 18 04-07-2010 03:20 PM
FS: Dashboard Covers for the '07-'09 LB, ProClip Mounts, 180mm Double Din Trim Piece IsLNdbOi Items for Sale by private party 14 09-25-2009 01:21 AM
FS: Garmin GPS Unit w/ ProClip Mounts, 180mm Double Din Trim Piece IsLNdbOi Items for Sale by private party 2 08-23-2009 03:37 AM
Canadian DD trim piece. Can any of you Canadian members get one? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 12-20-2008 01:52 AM
