Old 01-10-2007, 01:20 PM   #12
Fastnx
Drives: Nissan NX2000
Right, but it is important to know what final drive is and how a transmission works.
According to chinocharles, the engine's power goes through 4th gear, the speed is multiplied by 0.9xx and that's it. This is not correct.
The power goes through the clutch to the input shaft, then through a gearset to the output shaft. This gearset is different for every gear. The output shaft then travels through the differential, which reduces the engine's speed once again. Most final drives are in the 4:1 range.
So if your first gear ratio is 3:1 and the final drive ratio is 4:1, the wheels are actually travelling 1/12 the speed of the engine.
If your fourth gear is 0.9:1 and the final drive is 4:1, the engine is still travelling 3.6 times faster than the wheels.
The assumption that you have to dyno in the gear closest to 1:1 is false, since the power is going through a final drive, the wheel speed will never be close to the engine speed. If your dyno guy is telling you this, he is wrong. Just because you own and operate a dyno does not mean you know the science behind how a dyno works.
At a dyno I went to, the operator did not even know the fundamental relationship between horsepower, torque and RPM which is HP=(Tq*RPM)/5252.
Fastnx is offline   Reply With Quote
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
GROUP BUY - Megan Racing 4-1 Header... riceboy Items for Sale by private party 489 01-10-2007 06:45 PM
VA/MD Owners - Megan Racing Header ProMotionTuning Performance Modifications 4 11-30-2006 02:54 PM
HEADER & INTAKE R&D. WRLEO Performance Modifications 80 11-23-2006 03:51 PM
