Old 05-18-2010, 11:17 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
If you guys did all the bending yourself, you should have built it a lot wider and higher. There's too much crush area between the body and the cage to be as effective as a roll bar should be.
In the event of a side impact, the car would crush into the seat before it hits the bar. Same applies in a roll over.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 98 02-18-2024 06:45 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 08:20 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 02:56 PM
Installed TRD Strut + Sway bar Blenjar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 07-11-2007 12:46 AM
