Old 05-10-2010, 08:46 PM   #217
crazyandroid
Drives: 2007 Polar White Sedan
There is no polarity to the clutch switch, so you don't have to worry about which terminal on the switch goes to which of the two wires in the fuse box.
You simply run the two wires from the clutch switch to the two wires in the under-hood fuse box, and make your connections.
Thank you very much! I can't wait for my switches to come in!
crazyandroid is offline   Reply With Quote
Old 05-11-2010, 01:08 PM   #218
PhillyG
Drives: 2009 Yaris
hi guys.. i am very interested in doing this to my yaris. does this work for 2009 as well? i didnt see anyone mention this beyond 07-08.
PhillyG is offline   Reply With Quote
Old 05-11-2010, 01:23 PM   #219
Yes. 09 Liftbacks (and some Sedans) have the wiring in place from the ECM to the steering column, making the job even easier. Take a look at the following thread regarding the differences:
http://www.yarisworld.com/forums/sho...ght=diy+cruise
Old 05-11-2010, 01:48 PM   #220
PhillyG
Drives: 2009 Yaris
Thanks!! i am making a list now.. hope to get to do this in a week or two!
Old 05-14-2010, 12:57 AM   #221
crazyandroid
Ok, quick question. When installing the clutch switch, I see that the two wires go to the blue and white wires on that connection in the fuse box . . . could I just splice into those wires instead of trying to wedge some sort of connector into the same hole? I ask b/c that's what I tried and I'm not sure where my failure lies. I will take pictures in the morning of everything that I did and hopefully someone can help me. I'm really feeling like I should not have attempted this mod . . . I don't even know how to check the current to make sure that things are connected adequately.
Old 05-14-2010, 08:33 AM   #222
Definitely splice - Don't wedge. The wedging can be done for a quick test, but you really want a more positive mating for the long run.
Old 05-19-2010, 01:00 PM   #223
Yarisduder
Yarisduder's Avatar
Drives: 2007 4dr Sedan Silver Streak
Hi, I'm trying to do this on my Canadian 2007 Yaris sedan, and there's already a blue wire in the pin40 spot at the ECM. The wires on the steering column aren't there. Does this mean I can't have CC, or do I tap into that blue wire?
Yarisduder is offline   Reply With Quote
Old 05-19-2010, 02:41 PM   #224
If you are 100% sure that you are looking at the correct pin as pin 40, then indeed your wire is run from there to the junction connector under the dash. (But not from the junction to the steering column).
That junction is just under the top of the dashboard, so you can't get to it without removing the dash, so the easiest thing would be to tap the blue wire by where it enters the ECM.
Old 05-20-2010, 08:26 AM   #225
Yarisduder
Yarisduder's Avatar
It worked!! I am amazed and awed! The dealer told me they can't put cruise control on my car, and with a few old buttons and resistors, plus some scraps of wire I now have CC! Thank you all so much, you've saved the Yaris and my $25K for a new car that would be comfortable on long journeys.
Old 05-23-2010, 10:04 PM   #226
sk8manmike
sk8manmike's Avatar
Drives: 2007 Yaris 4d Sedan
What's the best way to go about splicing for the CC switch? Shave the wire coat and solder on to it?
sk8manmike is offline   Reply With Quote
Old 05-23-2010, 10:33 PM   #227
That, or use a properly sized tap splice.
Old 05-24-2010, 12:35 AM   #228
mick.wheelz
mick.wheelz's Avatar
Drives: 2006 NCP91R, 1991 ST184R
Send a message via MSN to mick.wheelz
has this actually been tried on an AUDM ECM, I know it does not work on euro models (they seem to run different engines/ECM's alltogether)
mick.wheelz is offline   Reply With Quote
Old 05-24-2010, 06:15 AM   #229
mick.wheelz
so i checked my ECM, pin 40 is dead.
Old 05-24-2010, 07:54 AM   #230
That makes sense. It seems that the cruise control functionality is only programmed in the USDM Yaris ECM.
Old 05-24-2010, 06:42 PM   #231
mick.wheelz
that sucks, who has a USDM ECM they want to give me :p
Old 05-26-2010, 04:38 PM   #232
PhillyG
Drives: 2009 Yaris
just a side note... i finally got my parts in today. had them shipped to work because for some odd reason shipping to a business is cheaper. was gonna wait till this weekend and do the install.. notice how i said was? well.... during some down time....... it was really super easy! especially since i read just bout every post on the CC subject. many thanks to everyone! it works.. and looks factory!
Old 05-28-2010, 03:04 PM   #233
sk8manmike
sk8manmike's Avatar
I've run into a problem: I can't get the black wire cover off of the ECM Connector A21.
I've read CTScotts tutorial:
http://www.yarisworld.com/forums/sho...+connector+a21
But i still can't get it off the top so i can insert the wire. I've feel like i'm pulling every direction in can think of to get it off.
Is there something I'm missing?
Old 05-28-2010, 03:31 PM   #234
Once you remove the tiewrap, to remove the black strain relief/cover piece you pry it out, or squeeze it and pull up. It is snapped into the back of the connector.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
