Old 05-10-2010, 04:30 PM   #11
Originally Posted by crazyandroid View Post
Hi there, I have been considering doing this mod and I am waiting on my parts (ordered switches, resistors, and wire from allelectronics.com); however I have one question. I did not see anywhere in here which wire goes where for the clutch switch. I have an '07 sedan w/ MT and I have the Toyota clutch switch, which has two posts and I see that there are two posts to connect to the CC switches in the fuse box. Could someone please clarify for me how to run the wires from the clutch switch to the fuse box connections, if it even matters. BTW, I will have extras of each resistor so if anyone wants em I'll mail them to you, just PM me.
There is no polarity to the clutch switch, so you don't have to worry about which terminal on the switch goes to which of the two wires in the fuse box.
You simply run the two wires from the clutch switch to the two wires in the under-hood fuse box, and make your connections.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
