![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
JEFF69dini , the technician said that the " BALL BEARING " you described is the source of our leak for the '08 sedan and that it's associated with the head gasket . Dye was used in the engine to locate the source . There's a ledge ( part of engine block ) above the " BALL BEARING " that is inverted that catches the leaking oil and mixes with the road dust , etc. . Then below the ledge it forms into a smaller square bottom where the oil drop forms ( this is looking up to the upper right ( passenger side ) hand corner of the backside of the engine block from beneath the car ) . Using a flashlight is very useful to spot the oil . Did you ever find out anything of your dilemma ? THANKS
| How many bottles of engine oil do you add? | hans_fh | General Yaris / Vitz Discussion | 23 | 05-27-2007 08:59 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
| About Engine Oil Changing Manual | hans_fh | DIY / Maintenance / Service | 4 | 03-03-2007 10:20 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
