#19 | |
#20 |
Hmm, this seems like something that I'd need to see a picture of to see if where I think it goes is right. I'm assuming that I'll see it on the factory switch when I pull everything off this weekend...
CTScott, do you have a copy of the service manual I could see or is it on paper?
#21 | |
Headlight Stalk Diagram.jpg |
#22 |
I forgot that those service manuals were there...
![]() ...but, I've got it! The metal hoop is simply a clamp that, once you remove the red part, holds the stalk onto the steering column. The only thing I'm wondering is, can I tape the clock-spring in order to keep everything in the same position once I put it back on. I'm thinking either this is one clever idea... or really dumb. (Yeah, that's nothing to do with the light stalk...)
![]() ![]() Last edited by jpmck03; 06-16-2010 at 09:34 PM. |
#23 | |
http://www.youtube.com/watch?v=LgWSzVeILhc |
#24 |
![]() CTScott, you are the man!
#25 |
Done and done!
| DIY - Liftback Intermittent Wipers via Stalk Replacement (v2.0) | CTScott | DIY / Maintenance / Service | 142 | 06-25-2024 01:47 AM |
| DIY Variable Speed wiper stalk install | DanQ | DIY / Maintenance / Service | 27 | 08-03-2017 07:22 PM |
| DIY Projector/HID (sedan) | Brian | DIY / Maintenance / Service | 145 | 02-05-2012 04:13 AM |
| Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison | CTScott | DIY / Maintenance / Service | 54 | 02-14-2011 08:58 AM |
| How To Smoked Sedan Headlight -DIY | zulhizainL902S | DIY / Maintenance / Service | 26 | 01-14-2011 02:12 AM |
