![]() Drives: sedan Join Date: Jun 2010
Battery light going cookoo! Flickers, steady, gone !
Have an 07 yaris sedan auto. Started during the winter the battery light would flicker constantly. Sometimes it wouldn't even come on like now it hasn't been on 2 hrs into this 700 mile trip.
My regulator on it's way? Alternator? I cleaned the ground and plug terminals from the alt didn't help. Battery seems good still cranks like new every time Thoughts? |
#2 | |
http://www.yarisworld.com/forums/sho...05&postcount=2 |
Drives: 2007 Yaris 3dr auto Join Date: Jul 2010
Any resolution to this problem? As of 3 days ago I am having similar occurrances with my '07 3dr Yaris. First started off as battery light staying on for 30 seconds to a couple minutes, and today while driving the battery light came on for 30 seconds or so, blinking a little then gone. Already had the battery checked.
The only recent maintenance done to my car excluding oil change & tire rotation was changing the failed water pump about 2 months ago. |
#4 | |
We've so many reported incidents of this here that you no doubt are suffering from the same issue. Search voltage regulator and read all about it. Has it been raining recently? Mine exhibits this behaviour after a fairly heavy rainfall. Flickers until everything dries out. Sometimes can take as much as a day of driving before it will disappear again.
Learning & Upgrading
Drives: 2006 Yaris 5 Dr HB Black Join Date: Apr 2010
I had the same problem before, got a 09used alternator from a scrap yard, below 200 with a year warranty. Now the lights never goes back on, and even the ABS light which had the same problem too.
For details, u can search for a username Adriaan, he got a detailed report about this, with detailed solution too, good luck!!!!! |
| battery light stays on but running fine | galactus | Mid-Atlantic | 13 | 08-15-2013 09:50 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
| Battery light stays on | RickLew | General Yaris / Vitz Discussion | 6 | 10-29-2009 03:07 PM |
| 6lb 6oz ultra light weight battery | heavystarch | Performance Modifications | 28 | 11-19-2008 06:02 PM |
