#19 | |
Audio Junky
#20 |
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
i did a evaporator thingy instead of going HHO generator route on my previous Taco. what it was, is like the hho generator but just vacuum line sucking in outside air bubbling the water and sucking up tiny evaporated water. I really have no hard evidence on the effectiveness, no scangauge to tell me if my intake was cooler or not or inst. mpg gauge. however at pump whether it was me thinking i was doing better or not, i got like 10% increase. around 21>23mpg.
I guess intaking just tiny evaporated water makes sense to cool the intake air, kinda how driving through a cold foggy morning. About taking too much energy to break water down to hho, theres the option of seeding the evaporator with hho, from one jar that has electricity running through it tubed to a sealed jar of water. Seems like it would make sense. Still im not about to do anything like this on my new Yaris. Even though seems like people get real life results, i might start reading up on http://www.hhoforums.com
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
#21 | |
Super Duper Biff Guy
Drives: from here to there. Join Date: Jul 2010
This is legal, and cheap and easy to make. The HHO it produces its not just Hydrogen its "HHO".... So it will be safe to put on the engine, and its high maintenance. However, it can be made from some stainless, and a few other things. If you read around you will see that the links given above are scams. I have been researching this for a long time. You should never buy one, they are not worth the money. Also, you will want to read into how you should set yours up. This is only going to provide a little HHO, unless you create an efficient cell. Citric acid is used, and you would want a closed system that will self circulate the liquid you choose. If you do it right, it will make a decent amount, and not get hot or brown. Hope that helps. |
