#37 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
I'll possibly get to it after a few more oil changes with conventional engine oil . The 2010 seems to have stopped leaking with 2 conventinional O.C.s . Took it over 160 miles earlier in 90 degree heat . Did a quick check not long after we arrived home and nothing far as I can tell . Will do a more thorough inspection tomorrow . Keep our fingers crossed . So , 127.0.0.1 you'll need to be more patient .
#38 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
only, perhaps, mask the problem. the problem remains you need to repair a seal or gasket there are no -liquid engine repair kits- |
#39 |
we'll see .
#40 |
boydstir
drain plug is leaking is my guess did you put a new drain bolt gasket on the drain bolt after you drained the oil ? all stop leak products a a bigger problem after you use it just like 127.0.0.1 is saying i fix the problem never will use half assed stop leak products in anything motor or tansmission of mine good luck with your oil leak should be a simple fix is my guess
#41 |
yes , always use a washer for the drain plug . There are pics of the leak . It's the plastic head gasket . Not a simple fix , quite a task . Don't use stop leak products . Would most likely void the warranty . Have been doing oil changes and working on cars ( nothing major ) for over 25 years .
#42 |
boydstir
do you mean under the black motor cover ? that comes off with to nuts then the valve cover is exposed just seems odd a 2010 springing a leak so eary on but it can happen to any new car
#43 |
boydstir
looks like a valve cover leak maybe
#44 |
Nope . Head gasket . For 2008 and 2010 . Located the leak for both .
#45 | |
fix a head gasket with prayer-in-a-can. |
#46 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
When did they start making plastic head gaskets? I've seen lots of plastic gaskets, including plastic intake gaskets, but that's a new one for me.
#47 |
Don't know . But I know hard black plastic when I see it .
#48 |
Napa's import line (Altrom) gasket for our Yaris looks to be layered steel with a coating on it; pretty typical for most.
![]() I don't think plastic, even if it's reinforced around the combustion areas would take the heat, but I've been wrong before. |
#49 |
It is definitely an MLS (multi-layer steel) head gasket.
#50 |
Thanks . That's it . Looks to be a smooth plastic coating . The leak is from the lower right corner of the gasket close to the timing chain . The area circled in BLUE is where the leak comes from both '08 and 2010 . The exposed part of the gasket runs under the upper head . Wouldn't know it was steel by looking and touching it . I'll call someone to find out if it's all plastic or plastic coated steel or other coating.
#51 |
2010 still leaks
. Checked it after 3 days and around 160 miles . Seems like when there's back pressure from within the engine when brake assist kicks in the leak(s) is/are worse ( 2008 included ) .
#52 |
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
Hershey are you planning to get this fixed on both? I cleaned mine pretty well about 600 miles ago and I see no leaks, I'm still using Mobil 1 Synthetic.
#53 |
will give them a little more time .
#54 | |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 08:18 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 05:22 AM |
| Noticed possible oil leak ... | Hershey | DIY / Maintenance / Service | 45 | 07-08-2010 12:51 AM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 02:55 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
