Old 07-10-2010, 10:29 PM   #1
DED1982
Drives: 2008 Absolutely Red 2 Dr Hatch
Send a message via Yahoo to DED1982
Scion XB/XD Silver/Dark Grey Leather Steering wheel
***PENDING SALE ON STEERING WHEEL... WILL UPDATE AFTER SALE***
Direct fit into our beloved Yarii. I'm getting out of the Toyota game though, and heading back to old school VWs.
Bought new, used for 1.5 years. Leather is gorgeous and feels so good to drive with. These should have come stock. Perfect match for the dash and silver center stack. Airbag not included. Plug and play OEM+ mod!
$150 plus shipping
Email ded1982@windstream.net or text/call me (478) 297-9969 - Doug
Also, if you're local, I'd be glad to meet halfway (anywhere in Georgia), in that case there would be no shipping
DED1982 is offline
Old 07-11-2010, 12:12 AM   #2
auxmike
auxmike's Avatar
Stick with Toyota, the VWs tend to spend lots of time in the shop. Nice wheel, BTW....
auxmike is offline
Old 07-12-2010, 10:35 AM   #3
bizzlebaby
bizzlebaby's Avatar
Drives: 4 Dr 07 Sedan
Pm sent
bizzlebaby is offline
Old 07-12-2010, 02:59 PM   #4
DED1982
PM replied!
DED1982 is offline
Old 07-19-2010, 11:45 AM   #5
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
did you get the deal done ?
pennyracer is offline
Old 07-20-2010, 11:50 AM   #6
pennyracer
boydstir
pennyracer's Avatar
hi im looking for info on what year scions will the steering wheel swap directly to a 08 yaris liftback any one have this info please advise
Old 07-20-2010, 11:09 PM   #7
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
scion tC wheel will fit directly.....all years 05-10 same wheel on the tC.....first gen xB and xA wheels will not fit
bzinn 1 is offline
Old 07-21-2010, 12:11 AM   #8
sleey0
Drives: 2008 Yaris LB
Found the part.
Now, how did you get the wheel off of the car?
sleey0 is offline
Old 07-21-2010, 07:58 AM   #9
I apologize to the OP for the thread jacking, but to answer the questions:
TC steering wheels fit, but the "notch" on the back of the wheel is different. The Yaris steering wheel has a an opening, where the Scion one has a bar. This prevents you from being able to perfectly center the steering wheel on the clock spring. I bought a TC steering wheel with the cruise stalk attached off ebay (for far less than a cruise stalk), so I did some experimenting with the TC steering wheel, as it is a nice leather one.
Yaris Steering Wheel:
Scion TC Steering Whel:
Yaris Clockspring (note the two tabs that the grooves in the steering wheel center on):
Here's a video that I put together to show someone how to remove the clock spring, which also shows removing the steering wheel.
http://www.youtube.com/watch?v=LgWSzVeILhc
CTScott is offline
Old 07-21-2010, 12:02 PM   #10
pennyracer
boydstir
pennyracer's Avatar
thanks for the heads up this helps alot you really know your stuff CTScott this is what makes this site so helpfull so does the binker shut off when the wheel retuns to the center position after a turn if thats what your mean by it not centering completly ? thanks again bud i want t tc leather wheel just want it work right the first time i install it
Old 07-21-2010, 01:09 PM   #11
Good questions - After eating lunch, I just mounted the TC one to Crashy. When I tried it before, I had the clockspring taped so that it would not rotate, so in order to slide the steering wheel on I had to cock it a few degrees.
This time I left the clockspring free and rotated it, instead of the wheel. Doing so allows the wheel to go on straight, and shouldn't affect the clockspring's operation, as it is designed to allow for 5 revolutions (so, ~5 degrees out of 1800 is fairly negligible). The turn signal return worked fine in both directions.
Here are some pics:
TC steering wheel mounted on Crashy:
Closeup of clockspring rotation required to put steering wheel on straight:
Airbag on - Not that the fit isn't quite as nice as the xB/xD wheel above:
CTScott is offline
Old 07-21-2010, 04:06 PM   #12
you have an airbag on Crashy?
cali yaris is offline
Old 07-21-2010, 06:24 PM   #13
Not any more. If you look closely you'll see the seams, where I glued the airbag cover back together.
CTScott is offline
Old 07-22-2010, 08:21 PM   #14
pennyracer
boydstir
pennyracer's Avatar
so now that is solved thanks again ctscott looks like the scion air bag has a much better look then putting on yairs air bag on scion wheel wonder if the air bags plug in the same way ? sorry for all the questions but i have another one whats the best winshield wiper controll swith to replace the yaris switch to gain more rear window wiper controll settings found one off a lexus 05 wonder if it will work number on the lexus switch is 17a082-lh
Old 07-22-2010, 08:59 PM   #15
From what I've seen the 2008+ Scion airbags have the same connectors as the Yaris airbag (and they have the dual squibs, unlike the Japanese Vitz airbags, which just have one squib).
For the Wiper stalk check out my DIY for part numbers. The place in the thread where I bought my Prius stalk from typically has them available. The part number that you posted is not a correct number, as it should have 10 digits.
http://www.yarisworld.com/forums/sho...ight=diy+wiper
CTScott is offline
Old 07-30-2010, 08:51 AM   #16
MUSKOKA800
MUSKOKA800's Avatar
Thanks DED1982.
Canada Post delivered today. The wheel was well packed and in pristine condition.
And thanks also to CTScott for the tutorial.
It'll help greatly with the installation.
MUSKOKA800 is offline
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
Leather Steering Wheel MGargano Cosmetic Modifications (Exterior/Interior) 29 05-08-2009 04:53 PM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
