#145 | |
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
Garm is permanently high because he is the king of smokin' deals! |
#146 |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
#147 |
Bathroom + Laptop = <3
Did you test the actuator cracking pressure with a regulator? Think you may be overboosting? Or have a leak somewhere in one of your lines? Try to put a MBC and cap it off if that is the case if you can't find the issue. If you are dead set on a new wastegate, and it does the same thing,, you have an issue with how you set it up.
#148 | |
C'est la vie
#149 |
It better to run a lower pressure waste-gate and use an electronic boost controller.
#150 |
^ +1 million
#151 | |
#152 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
Boost Spiking could be dangerously fatal to engine internals since your tune may not be rich enough for the amount of boost entering the engine. |
#153 |
C'est la vie
Well I removed my wastegate actuator today and tested it with a small compressor. It cracked at 13psi and did not completely extend until 18-19psi. In other words way to much. As far as the boost spike, I thought of that too. But it would hold and maintain 10psi in forth gear as well. For now I will take it easy until my new 7psi acuator gets here.
#154 |
C'est la vie
After testing the acuator and finding the spring is way to strong, I have rigged up a temp. fix until new actuator arives in mail [see pic]. I dont want to run lean and I will need to drive this car to work. The spring pulls to open the wastegate sooner. Right now tension is set around 6.5psi. I am now able to finally hit the gas without the drama. So I made a short video, http://www.youtube.com/watch?v=-2WwE2LF0ak
Also on my way to work a dropped Ford focus passed me very slowly and paused when they got in front of me. The passenger a young guy was pointing at my front mount. Then they slowed down and gave me thumbs up. I waved and hit the gas, as they tryed to keep up. Left them in the rear view. I accelerated to 100mph, and I got their pretty quick. Then I let off the gas and enjoyed my GLORY for a while waiting for them to catch up. I can say now its all worth it!!!!!
#155 |
cool man, sounds nice!
#156 |
This car is damn fun to drive boosted lol. I've been driving pretty conservatively until I get tuned as well. My only regret is not buying a manual three years ago. ![]() Now that we both got our turbos in... LET THE VIDEO WAR COMMENCE!!! ... eventually. ![]() Oh, and get your codes read pleeeeeeease. |
#157 | |
C'est la vie
#158 |
BBBrrrrrrrOOOOOMMMMM....Pssshhhhh ...BBBrrrrrrOOOOMMMMM....Psssshhhhh
#159 |
It's funny how YW had very few guys who were turbo'd, and almost none who wanted to explore using parts from ZAGE kits and what not; now you two guys come out of no where and do it at almost the same time as each other, and are successful at it! lol. wtf?
#160 |
^ haha, it's just the start of it, I believe!
#161 |
Well if you compaire the Echo/Yaris/Vitz to the Civic scene, they've only been around for 11 years now, as where the Civic was out nearly 20 years before it REALLY took off as a cheap tuner car. About the only thing we have going for us is the fact that the 1NZ-FE is still the same motor is was introduced as.
#162 |
^ plus the xB aftermarket, which was weak but did help with development
| Under $2500 Turbo Kit w/Intercooler coming soon! | cdydjded | Forced Induction Forum | 58 | 09-23-2007 02:02 PM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 01:24 AM |
| ZPI soon to release their turbo kit | turboyaris | Forced Induction Forum | 10 | 04-26-2007 02:52 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
