![]() Drives: Toyota Yaris 3dr Join Date: Aug 2010
A really good sway bar
Want to buy a rear sway bar. The bigger the better.
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
microimage sells ultra racing 23 mm. fattest available.
free shipping. bolts right on, hardware included. works great. see user "Cali yaris" if you wanna know more, or go to http://shop.microimageonline.com/Ult...R-AR23-100.htm |
Yes, I have the Microimage 23mm bar and highy recomend it. You need to look no further.
thanks for the replies. I will look into it. I would really like to improve the handling on this car. Will the bar be enough. I come from a 07 vw gti with stock suspension. Will it compare or will I need to do more? Thanks for the replies
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
Sway bar on stock suspension isn't going to cut it.
For the least amount of $, go with Tokico HP shocks and a set of Micro Image springs. Setup for less than $500. |
#6 | |
sway bar is the FIRST thing to install. then decide if you want to change other stuff. it has the most effect for dollar ratio...and it is the cheapest and easiest to install. that is all I stuck on my Yaris and I was blown away by the way it completely changed the car from a marshmallow in corners, to rather sporty |
#7 | |
I would suggest doing this first and get a feel from there how much further you want to go, and what your goals are. I'm in a 10 sedan, so it is not as tail happy as a LB might be. And realize the shock/spring combo will effect ride quality, how much depends on what you get and how much that means to you. |
thanks for the replies guys. I am going to take the plunged on the sway bar and then decided if anything else is necessary.
| My Ultra Racing rear sway bar install | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 49 | 03-03-2011 02:08 AM |
| front sway bar question | thom25 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 08-25-2009 07:54 PM |
| Got new TRD sway bar! | caineroad | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 08-24-2009 10:55 AM |
| Question about Sway Bar! | Ton | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 01-06-2009 03:31 PM |
