![]() ![]() ![]() Drives: 2010 Yaris Bayou Blue 3DR Lift Join Date: Sep 2010
I installed my own springs but that's only because I was getting quotes from $300-400 at local shops.
The only tool that I had to go buy was a Spring Compressor ($30) at Pepboys. Other tools you'll need, 6mm hex key, some people call it an allen wrench, 14mm/17mm/19mm sockets and wrenches, 17mm offset deepwell box wrench, you could use a normal 17mm wrench but a deepwell box would make life so much easier when you disconnect the front strut from the shock tower. And Jack stand. If you had to go buy everything, that's about $70-80ish. Heck, you could return the spring compressor and jack stand after you are finish, but that's kinda under-handed/dirty . . . . . . . ![]() P.S. Get nothing done at the Dealerships! They will bend you over, have their way with your wallet and make you watch! Seriously. |
| First timer Spring Installation | ZING | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 38 | 03-12-2011 09:44 AM |
| Quote on spring installation seems a little high | taracor | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 12-12-2009 10:38 PM |
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 05:02 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
| Track Suspension | id3379 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 85 | 06-11-2009 05:59 PM |
