Old 10-03-2010, 03:13 AM   #1
djct_watt
Drives: 2010 NCP91 5spd
Excessive toe out on an overloaded tire at a high roll angle = excessive rotation = oversteer.
djct_watt is offline   Reply With Quote
Old 10-07-2010, 04:06 AM   #2
ddongbap
So now you're going to the extreme. Might as well throw in bald tires into that mix then.
Might as well compare that to a RWD Yaris, on 195s, with 2000 hp.
Or lets just have a semi t-bone the rear quarter panel.
Thats some oversteer right there.
Old 10-07-2010, 04:13 AM   #3
djct_watt
I dont understand your point...
This is exactly what the bar does, "Yo." It does little in roll reduction (on its own) and only helps to increase toe with increased roll, which prematurely overloads the tire, which creates excessive rotation, which can lead to oversteer.
Old 10-03-2010, 11:56 AM   #4
Ryu
I have installed UR 19mm few month ago, my thought on this is that it will help your car to oversteer since the factory car is more on understeer side, and it will also help your car to be more stable under cross wind situation which I found much safer in windy weather.
Old 10-03-2010, 12:40 PM   #5
sickpuppy1
Drives: 2010 Yaris Sedan
The oversteer must be a HB/LB thing. On a sedan, with a 19 I get no hint of oversteer so far and I press it hard at times......Maybe not roadrace hard, but I do like to go for it at times...
Old 10-03-2010, 03:11 PM   #6
djct_watt
This is a FWD car. . . oversteer does not happen easily. It should not just happen from hard driving, but specifically when you push the car beyond the limit. But again, oversteer is a symptom of bad driving (either entering a corner too hot or a bad line). Despite all the Fast and Retarded Tokyo Drift antics, the fastest path through a corner is NOT sideways.
Old 10-03-2010, 05:40 PM   #7
sickpuppy1
I hear ya. Although not sure if they did it to be fastest through the corner, just the thrill and the skill of drifting. Cause for sure its not the fastest way, not even close.
Old 10-06-2010, 08:06 PM   #8
SimTronik
Machinist
Drives: Yaris sedan 2010
I'M an everyday driver but i like to push the car in some corners... whats the pros and cons of 19mm vs 23mm ?
SimTronik is offline   Reply With Quote
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
