Old 09-29-2010, 04:36 PM   #11
RedRide
RedRide's Avatar
OK........
A rear sway bar will firmly plant the rear end on the road and enable one to take corners faster with little body roll.
It goes without saying that if you push a car to the limits of you tire's grip you will kick the rear end out.
On reason maufactures build in understeer (eliminate a rear sway bar,etc) is to keep inexperienced drivers out of trouble.
An experienced driver knows the limitations of his car/ suspension/tires and does not push it past that point.
Having said that, a rear sway bar will reveal a bad tire's limitations. So, good tires will enable more of a rear sway bar's full potential.
BTW, an experienced driver is always more careful in the rain no matter what they are driving.
Personally, I felt rather unsafe driving the Yaris.
After installing the sway bar, I now feel much more safer and secure driving it in all situations.
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 06:25 AM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 07:07 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 08:20 PM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 02:05 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
