Old 10-14-2010, 01:11 AM   #11
pspeezy
Drives: 09 Yaris Sedan
Originally Posted by .Kevin. View Post
What is the name of the 3 lights in the inside of the vehicle
the two push ones and the switch one that turns on with the door opening
those are the bulbs I need x,x in red
the two push ones in the front are called map lights,
and the switch one in the middle is called a dome light,
(and obviously trunk light(s) is/are inside the trunk and license plate lights are the ones above your license plate)
im ordering my lights on friday, im not sure if it is different for 09 to 10, but the only festoon bulb i need is for my dome light, and the rest are 194 wedge type bulbs (map, trunk, and i believe on my license lights as well but not 100% sure)
for the festoon bulb for my dome light, i measured today in my car with a ruler, centimeters then converted to milimeters (1 centimeter = 10 milimeters) to know exactly what size (in milimeters) the festoon bulb should be.
(i suggest you do the same to be 100% sure, cause i feel more comfortable ordering my bulbs now that i have opened all of them up and checked them out)
pspeezy is offline   Reply With Quote
Yaris Throttle over-revs changing up Badger DIY / Maintenance / Service 26 08-22-2014 08:19 PM
changing alloys color zachryboles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-19-2010 10:38 AM
Just changing the blubs? Taiyaki In Car Entertainment + Electronics (audio / video / alarm) 5 04-21-2009 04:16 AM
Changing the oil lita_g DIY / Maintenance / Service 18 10-28-2008 01:59 PM
About Engine Oil Changing Manual hans_fh DIY / Maintenance / Service 4 03-03-2007 10:20 AM
