Old 12-27-2010, 01:34 AM   #1
swidd
Drives: Yaris HB
The Yaris has a feature that it will continue to crank for up to 10 seconds automatically, even if you let go of the key from spring-loaded START back to IGNITION. In essence, you can just "tap" the ignition, and the Yaris will determine how long to apply the starter for the engine to start.
Seeing as you've owned the Yaris for 5 years... eh? Maybe the problem is something else..
Old 12-27-2010, 10:49 PM   #2
dwoodpub
Drives: 2005 Yaris Hatchback
Thanks
Thanks for the response. I meant to say it is a 2007. It started doing it not long after I bought the car new. Every time I took it to the dealer it wouldn't do it.
dwoodpub is offline   Reply With Quote
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
Moving the Ignition To The Left? MadMax Cosmetic Modifications (Exterior/Interior) 4 10-02-2009 11:57 PM
