Old 11-30-2010, 07:56 PM   #325
cdydjded
Drives: Yaris LB Turbo
Pimp & Focus: did you guys mount your FIC's in the car or engine bay?
Old 11-30-2010, 08:44 PM   #326
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
let's hope in the car.
Old 11-30-2010, 09:03 PM   #327
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I was thinking of mounting mine in the front license plate area...that would be cool.....
if you believe this I have some awesome Ocean Front property in Oklahoma.
Old 11-30-2010, 09:13 PM   #328
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Mine is behind glove box door under dash. Their is a factory hole with a rubber plug just above factory ECM. This is where I ran my wiring. I drilled a second hole next to it for vaccume line to FIC.
pimp my yaris is offline   Reply With Quote
Old 11-30-2010, 09:14 PM   #329
pimp my yaris
C'est la vie
What spark plugs are U guys running? And what gap?
Old 12-01-2010, 01:25 PM   #330
Focus_Sh1ft
Focus_Sh1ft's Avatar
Mine's also under the glove compartment.
I've been wondering this too... How important is it that I change to spark plugs more ideal for a FI application? I was under the impression it really didn't matter.
Old 12-01-2010, 01:34 PM   #331
PETERPOOP
PETERPOOP's Avatar
copper plugs or Iridium plugs
Old 12-01-2010, 05:34 PM   #332
pimp my yaris
C'est la vie
I just installed some NGK BKR7E plugs. They did not have the iridium BKR7EIX in stock and they were 10$ each. I will see how these work.
Old 12-01-2010, 08:34 PM   #333
PETERPOOP
PETERPOOP's Avatar
What gap did you set?
Old 12-02-2010, 01:15 AM   #334
pimp my yaris
C'est la vie
Unfortunatly I could not find my plug gapper, so I installed strait out of package after looking them over.
Old 12-24-2010, 02:21 AM   #335
pimp my yaris
C'est la vie
For a long time I have had a occasional missfire under heavy load or full accel. I removed the spark plugs I installed previously and closed the gap to about half. I wanted to see if the smaller gap would lessen the load on the ignition coils, and it worked. No more missfire. It would cause a big jerk when it happened. Im sure the correct fix would be a stronger ignition system, but no flow for that now. Its nice when the car feels reliable like oem just with more power.
Old 12-24-2010, 11:31 AM   #336
I'm glad it worked, but I suggest you gap those with a tool when you have a chance.
Old 12-25-2010, 09:53 PM   #337
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
yeppers, i gapped my ngk vpower plugs at .22, i had that same problem. boost was blowing out my spark at full boost. was getting a jerk and misfire under hard acceleration. FYI, this was on my crx with 10psi, not my yaris
Old 12-25-2010, 11:34 PM   #338
Focus_Sh1ft
AWESOME. This is just the information I was looking for. Recently I've been having the same problem but it has become more noticable. I always thought it was the transmission jerking because it always happens shortly after a shift into 3rd(?), but this sounds more likely. The sudden loss in power is a huge buzz kill.
I'm gonna swap my plugs. Recommendations? Thinking I'm going to get the same plugs if those are the one's that are a step colder than stock.
Old 12-26-2010, 03:00 PM   #339
ilikerice
ilikerice's Avatar
i used vpower ngk for all my honda engines. personal preference, but hope one of these other toyota boosted guys will share thier thoughts on plug preferences.
Old 12-30-2010, 12:14 AM   #340
pimp my yaris
C'est la vie
NGK's should be used on any asian brand car. Nippon Denso's can be used if NGK is not available. And no matter what dont ever use Bosch. You will have nothing but headaches and missfire problems. And Champions are only for lawn mowers and chryslers.
Old 12-30-2010, 03:49 AM   #341
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I use Denso IK22 Iridium Tough Power. They are one step colder than stock.
http://www.globaldenso.com/en/produc...er/lineup.html
Parmas is offline   Reply With Quote
Old 12-30-2010, 08:11 AM   #342
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I've had bosch platinum 4's in my car for 30 000 km now with no problems. But on the other hand I'll be going back to NGK or Denso when these are done. the price isn't worth it.
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
