Old 01-31-2011, 08:00 PM   #8
Yaristeve
Drives: 3-door hatch
Originally Posted by Viperoni View Post
You don't gain any camber on the solid rear axle as it compresses... and you do want some.
Why would you want to? With solid axles (ignoring for a moment the change, if any, in camber due to the twisting) the tires remain perpendicular to the road which will give maximum lateral traction. That is the goal of controling camber gain in independent suspension.
How much camber results from twisting? Can't be much. Although I suppose in theory the twist beam acts like a semi-trailing arm...
question on Rear Hub Spacers mastaofdisasta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-02-2010 09:54 AM
Adjusting rear camber?? PHXDEMON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 63 10-23-2009 12:11 PM
New Product: Penguin Garage Rear Camber Shims! Penguin Garage Penguin Garage 11 10-22-2009 10:20 PM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Handling changes from rear hub spacers and minor concern. YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 07-10-2009 08:07 PM
