![]() Drives: 2009 Yaris 3dr hatchback Join Date: Jan 2011
Manual with no tachometer tips
So I just got a 2009 Yaris 3 dr LB on Saturday and am trying to adjust to driving with no tachometer. I like the car so far. I was hoping to get some tips. When I can hear the engine it is no problem, but I am always listening to loud music when I drive, and I can't hear the engine when I do.
I drove a 01 Hyundai Accent for years and it drives way different. this is what I generally do: 25 mph - 3rd gear 25-40 mph - 4th gear above 40 mph - 5th gear Does that seem right or is there another method to get used to. I was thinking of getting an ecometer or scangauge but i read that there is a delay and can't be relied on as a tachometer. any advice would be great. |
![]() ![]() ![]() Drives: 08 2Dr LB Base, Silver Join Date: Jan 2011
It's an econo-car (exactly what I wanted). Upshift as quickly as you can, and if it's too soon, you'll know. After a short while, you'll just get used to how it feels.
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
Now been Yaris-ing for more than 3 years. General rule for "everyday" driving -
1st gear - 0 to 10 2nd gear - 10 to 20 3rd - 20-30 4th - 30 to 40 5th - 40 and up These change when going uphill, and for hard acceleration remember that she'll do 64 in 2nd before red-line, and around 90 in 3rd. Uses more fuel, but if you need to speed up in a hurry, them's the limits. |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
But if you join an interstate, or want to race some bitch to merge in front of her, try 3rd gear to 65, 4th to 80, 5th to cruise at 90.
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
after awhile you can feel the powerband taking off. You can feel the car stops picking up speed then you shift to next gear
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
The tach on the ecometer updates twice a second so it should be plenty accurate for daily driving. If I'm not mistaken it's the same for the SG. Priced nice and easy to "install" plus the other features and benefits.
![]() Drives: Yaris 2 Join Date: Sep 2010
if you need a tach to drive , maybe you should get on a bus instead and off the road since your constant gawkin at the gauges will get someone killed
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
I've used both an EcoMeter and an Ultra-Gauge which both have a tach function. Both are OK for that but as stated earlier the ecometer updates twice a second and the ultra-gauge updates only once a second. Both fine for daily driving. But after using both I;ve come to realize that, for a tach, theres nothing like the instant feedback of a regular, purpose-built tachometer gauge with a sweeping needle and lit numbers. It just feels "right" and a quick glance, or even just in your peripheral vision can tell you exactly what your engine is doing. However, I'm very happy with my ultra-gauge and fully recommend it for all its functions, and the tachometer display on it is a nice bonus for "normal" driving.
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
![]() ![]() ![]() Drives: Loaded 2007 mica silver sedan Join Date: Sep 2007
| Tags |
| advice, manual, tachometer, tips, transmission |
| Remote Start DIY Wiring Guide 2006-2010 Yaris | CTScott | DIY / Maintenance / Service | 272 | 01-22-2022 11:02 PM |
| C54 MANUAL TRANSAXLE service manual needed | ricepower | DIY / Maintenance / Service | 1 | 08-29-2007 08:24 AM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 05:25 PM |
| The Toyota Authorized Repair Manual. | LoudYar | General Yaris / Vitz Discussion | 3 | 03-29-2007 01:20 AM |
