Old 02-15-2007, 11:14 AM   #11
Snake
Send a message via AIM to Snake
the motor you guys have in your yaris just doesnt have the capabilities to produce the power you want, dont waste too much on the 1.5
I doubt anyone can push over 185 hp with a good amount of boost
if your looking into a 2zz swap, im sure its not going to be too difficult
you can buy a used 2zz from a toyota matrix, celica gts, or vibe gt
they come pretty cheap, the one i bought for the mr2 cost me 450
im looking into if our c50 trans will work with the 2zz motor, if people can post some pics of the c50 trans then this will help
as for engine management, you can run a hydra stand alone for the 2zz
if you want to run close to stock, you can swap the yaris computer for a celica gts computer if thats possible, i know they do it on the mr2's with a special wiring setup someone designed from the spyder forums
a similar setup can be made
if anyone is serious about doing this swap, i believe it is very possible and a little bit more research has to be done
with a built 2zz and boost, you can push over 350 fwhp, think about it?
Snake is offline   Reply With Quote
Yaris Engine Christopher General Yaris / Vitz Discussion 1 01-17-2007 03:14 AM
engine modify Yaris D-4D uraz Performance Modifications 10 04-30-2006 11:53 AM
