Old 04-07-2011, 12:21 PM   #11
bad_bwoy007
bad_bwoy007's Avatar
Drives: 2010 8T0 Yaris Liftback
Thanks for the quick response.
So is this how the relay should be hooked up?
If so, what would you use as you 12 volt pulse to activate the relay?
The Starter output?
PIN-1 YELLOW Starter Output-This wire will test 0V when the key is off, in the Accessory position and when
the Ignition is in the on position. The starter wire is 12volts during the start/ crank position only.
bad_bwoy007 is offline   Reply With Quote
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
