![]() ![]() Drives: Toyota Belta Join Date: Feb 2010
This vibration issue still persists. It's very annoying, it goes away when you clean the spark plugs but after 500-600 kms the vibration comes back again.
Any solid solution to this, anyone? |
![]() ![]() Drives: 2007 Toyota Yaris LB Join Date: Mar 2007
![]() ![]() Drives: 2007 toyota yaris sedan Join Date: Jun 2015
Replace starter and check battery and alternator.
When was last tune up? |
Just replaced them 1,000 kilometers back.
It's the vibration that is annoying. This thread is old, the rough start was due to an old battery, had replaced it and that issue was resolved. |
STP super concentrated Fuel Injector cleaner*
Don't use this crap. |
![]() Drives: 2008 Yaris Base Join Date: May 2014
For the hard starting you might want to replace the Engine Coolant Temperature sensor. They can be defective even with no check engine light. What's probably happening is that the ECT is giving an incorrect reading and the car is getting too much fuel at start up and may be causing fouling of the Spark plugs and hard starting symptoms.
Last edited by ricardocanedo621; 08-15-2015 at 01:01 PM. Reason: Correcting Grammatical Errors |
![]() Part Number: 8942233030 Amayama.com has it for $22 USD and ships worldwide |
| DIY - 1.8L 1ZZ-FE TB Connector Chip Swap | Yaris T-Sport | DIY / Maintenance / Service | 332 | 04-03-2022 01:39 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Car wont start - help! | tamo300 | General Yaris / Vitz Discussion | 14 | 03-23-2010 10:44 PM |
| Rough engine start w/76? | guyver408 | DIY / Maintenance / Service | 12 | 06-26-2009 12:18 AM |
| Rough Idle in drive | toyoman | NY / NJ/ CT / PA | 8 | 04-22-2007 03:40 AM |
