#19 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
my original plan was to use a HushPower in the middle, but i have a million other things that need money first, so i used what i had...the 2 borlas used to be in a rear section that i had for my scion...i had 3 different rear sections to go with a custom front section
![]() ![]() the exhaust isn't really that loud, so i'm not going to bother with it for a while
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#20 |
That's a different setup than you have in the video... any vids of that?
I was thinking of doing something very similar in my Echo. Also, do you have any relatively inexpensive sources for 1.75" v-band flange kits?
#21 |
Can we hear that plz?
#22 | |
Obsessed with 1.5L
i was showing where my resonators came from...& actually they originally came off a 2 week old Borla exhaust for a 350z i tend to keep stuff thats in good shape (which i why i have 38 mufflers in my shed & 4 next to my toolbox)
#23 |
Thats a sick set up extremely nice!!!!;0)
why didnt you go with 2.25in wxhaust piping? |
#24 |
#25 |
Obsessed with 1.5L
2" is a perfect match for these motors to develop a good peak velocity that broadens the torque range
i could by looking @ the pics of how the heat is dispersed, drop down to 1.75" after the first resonator & probably see no difference in power output
#26 |
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
if i take the stock axle back (for sedan) and cut the last res box out and just weld a pipe where it used to be will it open up the sound a little ? i think i saw some one on here did that is it possible ?
#27 |
Going Retro
Drives: '09 Tacoma | '90 Tercel Join Date: Aug 2010
Well thanks for the heads up man. I got a friend down in Towson near Baltimore with an 86 rolla, when I got the spare change I'll bring down a header and muffler and let you set up a sweet low-restriction 2" exhaust with racing cat, ok? :)
No resonators for me. I like it LOUD. :D |
#28 |
#29 |
hey is this on a sedan i want to get a dual tip is this welded on cause the end of the oem is angled down so i feel like a dual would only work if it came out straight
#30 |
Obsessed with 1.5L
i'm probably going to take off the exhaust & sell it...i only got 49.81 mpg on the last tank...& it should of been a 50-52mpg tank
fuck me
#31 |
Yes, this is on my sedan. If you want to do a center exit tip like mine, you'll need to cut off the rear jack point. Just a heads up.
#32 |
#33 |
#34 |
#35 | |
Obsessed with 1.5L
so for like the first 15miles i'm on back roads coasting as much as i can & of course keeping speeds down ![]() my current tank is probably going to be low to mid 40s, i've been driving fast & using a/c...since i'm in the middle of some body work on my tercel...i have to take out my speed aggressions on the yaris, lol
#36 |
Obsessed with 1.5L
exhaust is for sale, i'm putting the stock exhaust back on
| DIY: Installing Greddy TI-C Exhaust System | redyaris | DIY / Maintenance / Service | 13 | 08-01-2009 04:05 AM |
| MacNeil Automotive products misrepresentations | tomjasz | Cosmetic Modifications (Exterior/Interior) | 44 | 11-05-2006 04:06 PM |
| What aftermarket exhaust will fit the Yaris Sedan? | dngz | Performance Modifications | 2 | 10-02-2006 01:41 PM |
| Performance exhaust systems for yaris | aucorium | Performance Modifications | 6 | 08-16-2006 08:12 AM |
| Toyota Performance Exhaust for Yaris HB | bigsky2 | Performance Modifications | 16 | 06-02-2006 10:21 AM |
