#11 | |
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
Look at it like what a previous poster said. If something has a set angular velocity (let's say 2,000 rpm), then you can determine the linear velocity at different points away from the center. The linear velocity at a point away from the center is (omega) * (r). (Omega) is the angular velocity, (r) is the radius. Looking at that basic equation, the larger diameter has a larger linear velocity than the smaller diameter since (omega) remains constant. Tires and the rolling diameter is a different can of peanuts because they are driven from the center and the outer diameter. Again, I'm just trying to help confusion, and not be a blankity-blank. |
| one brake light out | xartrax | DIY / Maintenance / Service | 3 | 01-27-2011 12:40 PM |
| big brake kit | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-13-2007 01:44 PM |
| big brake kit | yrsdrgn | Performance Modifications | 17 | 02-20-2007 11:05 PM |
| cheap trd big brake kit *joke* | birdy | Off-topic / Other Cars / Everything else Discussions | 3 | 06-13-2006 12:04 AM |
