#325 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan 2010 "shadow" Join Date: Mar 2010
sa pagkakaalam ko rin pre hindi mawawala ang warranty kahit sa labas or redcap ka nag pa change oil
#326 | |
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter) |
#327 | |
It depend on the damage and warranty claim..I have confirmed this scenario with multiple service advisors of ALJ.. From 2007+ models up, warranty is 100,000 km or 3years whichever comes first. Example scenario 1: 500km - casa/ALJ 1000km - casa/ALJ 5,000km - gas station/redcap/garage etc.. 10,000km - gas station/redcap/garage etc.. @15,500 - engine has an abnormal noise and need to open/overhaul the engine. The ALJ will check their system via vin/plate # if car is being maintained by their branches. They will take a snapshot of the engine and video/sound clips and sent to the main office for approval. THe chances of DISAPPROVAL is more as no consistent record of maintenance. Even you will say/show the receipts of your changed oil from outside. Sure they will say that there are other check to be done other than change oil or easy to produce receipts. You will shoulder all the expenses.. ** Above SR3000 worth of damage parts needs approval from their Head Office. Scenario 2: You just installed an aftermarket alarm from outside. The installer just cut and splice the wires of original vehicle harness. After few days, the MIL lights came on and ended up an electrical problem and ECU error. The harness has to be changed. Warranty is void.. Again, You will shoulder the expense. AS for me, again I will repeat AS FOR ME..I will not take the chances, once you decide that you will have it service outside or such itchy in moding your car like ME ; YOU ARE READY for the possibilities of having out of warranty...Lastly, if you evaluate the cost per maintenance period konti lang ang difference nila at di lang change oil ang gagawin..So mas mabuti nang ipasok sa casa para may Peace of Mind..Kung nagkaproblema man, walang hassle sa warranty claim.. my 5 halala opinion |
#328 | |
![]() ![]() ![]() ![]() ![]() Drives: YaRis ka!--Y?2011 Join Date: Jan 2011
#329 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris YX Join Date: Jun 2010
#330 |
#331 | |
#332 |
@ricepower, what about this kind of scenario:
@1000km - ALJ @5000km - ALJ @10,000km - Redcap (change oil = synthetic) @20,000km - gusto kong bumalik sa ALJ, ...any consequences? |
#333 | |
1000km - 40000km ALJ 45000km - sa labas 50000km - ALJ (wala naman naging comment ang ALJ) like what i've said... yung shop na sa labas, doon sila nabili ng supplies sa toyota... kaya parehas lang ang gamit.
#334 | |
20k - Major 1 40K - Major 2 --> ito yata ang pinaka mahal 60k - Major 3 OK lang ito..ang mahirap is ung nasiraan ka sa engine at d ka nag pa service sa toyota... As I said only in the earlier post..sa Toyota hindi lang change oil ang gagawin sa kotse mo..may added checks based on the required maint schedule..At puwedeng mag free request like spongy yung clutch/brake..paki bleed nga! and Oh..youre having an air leaking noise, will request for rubber replacement for free. Kung sa other shops, madalas change oil lang sila or same oil na gamit ng toyota but they will not perform other checks like i.e, tightening of bolts, underchassis checkup (leakage/cv boot check, belt check)..Mas lalo na kung butas lang at wala silang hydraulic lift
#335 |
#336 |
#337 |
#338 |
9400km..change oil @RED CAP.....
sr.158=4ltr oil/ 128sr +30sr labor + tip (sa akin ang toyota oil filter 15 sr) general check up with tire rotation CASTROL MAGNATEC KEEP YOUR CAR AT ITS PEAK Make an intelligent move. Use Castrol Magnatec. Uses Synthetic Technology Recommended in use for all types of high performance luxury cars (Petrol and Diesel) Best – in – class API SL/CF Formulation Viscosity: SAE 10W-40 How do the Intelligent Molecules work? SEEK: Magnatec's Intelligent Molecules seek out and bond to critical engine parts, providing active and continuous protection against engine wear where it's needed most. Not only do the Intelligent Molecules work from the start, but they also protect throughout the entire journey under all driving styles, conditions and temperatures. BOND: From the moment you turn the key, Magnatec's Intelligent Molecules are ready and waiting with an active layer of protection. As your engine heats up, the Intelligent Molecules become more active strengthening the protective layer to safeguard the components that need it the most during stop-start driving. PROTECT: As your engine gets hotter, other Intelligent Molecules are activated, bonding to vulnerable areas and forming an extra layer of active and continuous protection for driving on the open road. And when your journey is over, Magnatec’s Intelligent Molecules continue working, remaining as a protective layer, when your engine is turned off, ready for the next time you turn the key............... |
#339 | |
#340 |
Originally Posted by ricepower View Post
AS for me, again I will repeat AS FOR ME..I will not take the chances, once you decide that you will have it service outside or such itchy in moding your car like ME ; YOU ARE READY for the possibilities of having out of warranty... @rice power ..yan ang ibig kong sabihin na laging handa...pati pambayad...once na nag pa service ka sa labas at mahilig sa modification/cosmetic interior exterior ..ready dapat sa gastusin di ba?....parang boy scout laging handa..heheheh |
#341 | |
![]() ![]() ![]() Drives: Flint Mica 2010 Join Date: Jul 2010
#342 |
"i R i S H"
Drives: Toyota Yaris 2010 Join Date: Sep 2010
iRiSH 20K Maintenance at Petromin = SR 102 plus free engine wash
Nagpunta akong RedCap kaso sobrang haba ng pila kya tumuloy nlng ako sa Petromin..Kabayan din nman dun at Toyota Oil pa din pinalagay ko. |
| how much does the first maintenance service cost | hans_fh | DIY / Maintenance / Service | 25 | 07-05-2007 10:01 AM |
