Does it run through the coolant though? Or is it just a loop in front of the lower part of the rad. That makes a difference. If it's going through the rad the transmission temps should be pretty close to the coolant temps. If it's an open air loop in front of the lower part of the rad it won't be getting the airflow it requires.
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| 2007 Toyota Yaris Temperature Question | bhola | General Yaris / Vitz Discussion | 17 | 06-25-2010 07:46 PM |
| Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder | bieniman | DIY / Maintenance / Service | 4 | 05-20-2009 12:40 AM |
| Temperature Guage install | bieniman | DIY / Maintenance / Service | 3 | 03-12-2009 03:45 PM |
| Water temperature | Bob_VT | General Yaris / Vitz Discussion | 11 | 11-03-2008 04:17 PM |
