![]() Drives: Yaris Join Date: May 2011
Lights On Alarm
My alarm is not sounding when I open my door when I leave my lights on. Is this controled by a fuse? If so, which one?
#2 | |
By alarm, I assume you mean the warning chime? If so, the chime is part of the instrument cluster. Does the chime sound if you start driving with your seat belt unlatched or if you start backing up with the ebrake on?
That is what I mean and yes, they work most of the time. I have noticed every once ina while they don't.
Hmmm intermittent and not working with the brake either seems like a issue with the cluster itself, but check the PANEL1 fuse in the under dash fuse panel.
I will do that....Thank you. I will let you know.
| Factory Alarm on my '08 Liftback is Too Sensitive! | alex_melodymaker | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 06-07-2011 03:21 PM |
| Fog lights, or parking lights stopped working | sylvermagyk | DIY / Maintenance / Service | 4 | 03-24-2011 05:13 PM |
| Alarm Wiring Advise Needed | Lil Abner | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 09-26-2010 10:11 AM |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 02:02 AM |
| Audible alarm when lights left on | dobsona | General Yaris / Vitz Discussion | 21 | 02-18-2009 09:54 AM |
