Old 06-07-2011, 11:12 AM   #6
Originally Posted by 49erRider View Post
Ok so it was a blown fuse. Now the problem is it is blowing fuses as soon as they are put in. How or where do I look for a short?
It is more likely a jammed mechanical linkage than a short. If you pull the hatch trim, you can get at the wiper assembly. There are two screws that mount the motor to the gearbox. If you pull the motor off of the gear box and run the wiper, the motor should spin and if it doesn't blow the fuse then something is jammed in the gearbox. Four more screws hold the cover on the gearbox - remove those and see if it is something fixable.
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
Does your Rear wiper sqeak like crazy? is this normal? Syroyizhka DIY / Maintenance / Service 18 04-16-2009 08:11 PM
