Old 06-26-2011, 07:57 PM   #7
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Originally Posted by revolution View Post
A Split System is Speaker System where the tweeter is provided separate to your mid-range speaker. A crossover then splits the sound from your radio so that the mid and bass goes to the mid-range speaker in your door, and directs all the treble to your tweeter which is mounted higher up in your pillar, etc...
Got it!
Components with a passive x-over!
I don't use passive x-overs any more. (o:
"Does the Mid-Range on a Split System need to have a speaker grille or will it still sound OK even if its covered by the door panel"
As long as you don't cover the tweeter with a grill the Mid/bass speaker will be fine even with stock location in the panel.
D.
CLA 250, 4MATIC
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
