Old 06-26-2011, 10:11 PM   #8
Lil Abner
Drives: 2009 3dr LB Manual
Got it!
Components with a passive x-over!
I don't use passive x-overs any more. (o:
"Does the Mid-Range on a Split System need to have a speaker grille or will it still sound OK even if its covered by the door panel"
As long as you don't cover the tweeter with a grill the Mid/bass speaker will be fine even with stock location in the panel.
D.
Actually, I think you read that wrong. The way I read it, he's asking if he can put the mid-range speaker behind the solid plastic door panel. If that's the case, then NO, that's NOT ok. The speakers needs those "holes" in the speaker grille to let the sound pass through. So if you put a speaker behind a solid plastic door panel, you won't hear much.
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
