Old 06-29-2011, 12:50 PM   #8
The reason that I am thinking fuel issue is that it takes so much to get it going, but once it is running it stays running fine. I am thinking that when it sits that sediment settles to the bottom and it takes some work for the fuel pump to suck past what's stuck to the filter to initially get running. Once running, the fuel pump has a little bypass hole that washes the surface of the filter, so that may be why once it is running it stays running. I too could be wrong, but it makes sense to me.
Also, there is a fuel filter. It is a plastic mesh one that snaps onto the bottom of the fuel pump. It is replaceable, but requires pulling the fuel sender assembly to do so. That's something that you'd really prefer someone else to do for you on their nickel if possible.
Tags
engine, problem, starting
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
FS: 2009 Toyota Yaris Taiyaki Hawaii 7 11-02-2009 08:47 PM
