Old 07-19-2011, 08:57 PM   #16
Brian
Brian's Avatar
You can either mount the sender in place of the OEM one or use one of the adapters where you cut the radiator hose and install it in line (like the pic below). By the time you spend $50 for a decent gauge (or the same as a SGII for a good one) and go through the hassle of installing it, you'd be better off with the SG.
You can't remove the OEM temp sensor. You would need to add a t-fitting and add an aftermarket sensor while still retaining the OEM sensor. I tried just replacing the OEM sensor with an aftermarket one when I did my other gauges install and I got a CEL P0118 and the car wouldn't start or when it did the idle was very low and the engine would stall. I put the OEM sensor back in and everything worked perfectly.
Shorter Serpentine Belt? The Architect Performance Modifications 6 04-20-2021 10:42 AM
anyone has a DIY change serpentine belt on yaris sedan rufnnek DIY / Maintenance / Service 0 06-16-2011 06:15 AM
Serpentine belt broken with oil on it HerYarisNotMine DIY / Maintenance / Service 10 05-31-2011 02:51 PM
serpentine belt for 2007 yaris hatchback nikki9 DIY / Maintenance / Service 4 04-09-2011 09:22 AM
serpentine belt 1.3 engine `psycho DIY / Maintenance / Service 2 04-08-2011 10:40 PM
